Cayin N5ii Technical Support thread
Discussion in 'Portable Source Gear' started by seanwee, Mar 28, 2018.
6 7 8 9 10 11 12 13 14 15
  1. carpler
    I ask if the cue sheet support is complete for the N5ii.
    I can select a cue sheet file and the native player recognize all the tracks, but while playing it seems to be no very gapless reproduction (I listen some click between tracks).
    I'm the only one or others notice this behaviour?
  2. snbrp
    I agree with you and wrote about this bug on page 2. Gapless mode don't works correct with cue.
    carpler likes this.
  3. carpler
    Thank you for confirm this.
    I hope Cayin will fix this sooner or later...
  4. snbrp
    But I don't think so. Cayin spend all resources to "USB Audio" and other modern features and don't want to make basic functions work perfect :frowning2:
  5. CayinSupport
    Is your firmware 3.1EN? Could you please send your cue files to my email community@cayin.cn for a test? Our engineer said our cue files worked perfectly on our side.
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
  6. CayinSupport
    This is man-made damage and you will bear all the fees if you want to replace its screen. I think there is no need to replace the screen if it doesn't hamper normal usage. But finally, it totally depends on you.
    http://en.cayin.cn/
  7. zabin29
    Understood, can you give me an idea of the cost to replace the screen? thanks for the reply, you can pm me if you want.
  8. CayinSupport
    I will PM you
    http://en.cayin.cn/
  9. zabin29
    Got it thanks
  10. seanwee
    For everyone with the playback freeze issue, i suggest backing up your sd card, reformat it, the copy everything back in. So far it seems to work.
    somnarium likes this.
  11. Slater91
    This does not seem the case for me - I just replaced my 64 GB Samsung card with a brand-new 128 GB Samsung card and made no progress. I also copied the files over from the HDD and many are not even the same (I got 320 kbps MP3s on the old card, FLACs on the new as I re-ripped my collection and only have FLACs now). I really do wonder why there are so many differences in behaviour between different users...
  12. seanwee
    Serial number? Others have suspected it may be a batch related issue.
  13. Slater91
    SLC520603575.
  14. seanwee
    That seems to be the 3575th unit. Mine is the 2414th unit. That rules out that only early batches are bad. Yours should be newer than mine if I'm reading it right.
    Does your model have a silver or gold scroll wheel?
  15. ethanduong
    I want to buy this DAP to use as an USB transport with my GO2Pro Infinity DAC/AMP (which only has USB input). So I wonder if it would work with a USB Type C to Micro-USB cable - Whether the Cayin N5ii supports it.
