Cayin N5ii Android based Master Quality Digital Audio Player
post-14315558
Post #2,581 of 4,040
ngs428
USA
USA
@Andykong thanks for the replies here. Very informative. Any thoughts on when the lyrics issue I reported and you confirmed will be resolved? Hopefully on the next release.
Listening to it now and am staring at a bunch of time stamps when there should be lyrics.
Thanks Andy!
post-14315860
Post #2,582 of 4,040
Thanks Andy!
Yes, we have reviewed the case, we should be able to resolve this through a firmware update. :beerchug:
http://en.cayin.cn/
post-14317066
Post #2,584 of 4,040
Dcipar81
The upside-down
The upside-down
I do have another question for Andy or anybody with insight. I read in a more recent thread on head fi that the modified version of Android that the n5ii uses doesn't allow users to download tidal content to an external so card. Is this actually the case that the n5ii blocks apps from recognizing external ad cards?
post-14317316
Post #2,585 of 4,040
I have explained the problem previously:
https://www.head-fi.org/threads/cay...tal-audio-player.862763/page-73#post-13991523
The situation remain unchanged, I have sent them an email to alert them but Tidal has done nothing along this line so far.
We have release the storage access right to third party applications and other streaming app such as Spotify can select offline download location is a prove of that. For reason that we can't figure out from our part, up to this moment, Tidal couldn't recognize the TF cards in N5ii and assume the internal storage as the only storage option available. This is very different from what you have described.
http://en.cayin.cn/
post-14319860
Post #2,586 of 4,040
CongoFather
Base on the last firmware progress report I received, the USB Audio issue is still ongoing. We start to deploy resources back to this issue after we released v3.2en, make some progress but no significant achievement till two weeks ago. Our target is to solve this problem by end of June.
Hi @CayinSupport @Andykong ,
Have you made a progress and solved the isssue related with USB Audio? It is almost the end of June. We'd like to hear some details about the current status, if possible..
post-14322658
Post #2,587 of 4,040
wakokokoyz
is it possible to use TF cards as storage for spotify? i keep loosing my files after reboot
post-14322823
Post #2,588 of 4,040
Sad to report, we make some progress, but not enough. We tried various options but still couldn't resolve the excessive noise issue in USB Audio completely, we managed to improved the compatibility while we investigate our bottom layer of USB related coding, but the noise issue is still remain Work in Progress status.
http://en.cayin.cn/
post-14322835
Post #2,589 of 4,040
That's strange, this is our second report regarding Spofity losing the downloaded playlist. I assume you are using v3.3en firmware?
We have positive reports from Spotify users since we launch N5ii, so it is kind of strange that we have two similar reports within a short period. The situation apparently affecting some users but not everyone. Can I check with other N5ii who has Spotify account? Can you please help us to verify the situation by download some of your Spotify music to TF card of N5ii and observe if they are working alright?
@CayinSupport will contact you to collect more information about your case and advise some testing to help us narrow down the problem.
http://en.cayin.cn/
post-14322838
Post #2,590 of 4,040
seanwee
Sounds like it might be caused by a Spotify update rather than the N5ii.
Did Spotify get updated recently?
post-14322847
Post #2,591 of 4,040
CayinSupport
Sponsor: Cayin
I have already PM you. Please check your PM box.
http://en.cayin.cn/
Reactions: wakokokoyz
post-14322869
Post #2,592 of 4,040
wakokokoyz
ill test some more this evening. what should be the format of the TF card?
post-14322951
Post #2,593 of 4,040
http://en.cayin.cn/
post-14323183
Post #2,594 of 4,040
wakokokoyz
it seem exfat fixed it. previously in Spotify, got 128gb on exfat and 64gb on fat32. then when i select the 64gb as storage, both SD cards are highlighted. now, with 64gb on exFat, only the 64gb is highlighted. ill continue testing it. ill update here if anything weird happens. thanks to the active support team
post-14323274
Post #2,595 of 4,040
Dcipar81
The upside-down
The upside-down
FWIW with my other android DAP (the one I'm selling to switch to Cayin due to lack of support from the developers, thanks Andy) if you leave Spotify running when you power down the device or it goes into sleep mode then all the offline content is lost. It still takes up space on the TF card, but is not recognized by Spotify. If you continue to have trouble with your device, try that and see if it helps. It certainly is a pain to have to remember to actually shut off spotify every time, but if it saves a little headache it's not that hard a habit to get in to.
