Cayin N5ii Android based Master Quality Digital Audio Player
Discussion in 'Portable Source Gear' started by PinkyPowers, Oct 14, 2017.
160 161 162 163 164 165 166 167 168 169
171 172 173 174 175 176 177 178 179 180
  1. Andykong
    I don't think there is any option to "synchronize" your iTuen library with an Android device. iTune only provide one time conversion to export the music to non-iOS device, personally I am not surprised as Apple ecosphere tends to motivate their customers to stay within the iOS domain. When you said you "had frequent errors interrupting the copy of files to the SD card", do you mean connecting the N5ii to your iOS device and copy the 110GB music library to the SD card directly? Maybe an external card readers will offer a faster and more reliable operation.
    N5ii does not support Airplay and the native HiBy player does not feature a special connection with iOS device, you probably will need to rely on the Bluetooth function only, which is indeed not as good as AIrplay. I'll am not family with iOS system so I hope other users can confirm the feasibility of third party applications regarding streaming to iOS devices.
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
  2. wakokokoyz
    i understand. thank you and i appreciate your prompt reply =)
  3. amahikas
    Hi,
    I am a Cayin i5 user, and a Mac Book Pro user.
    I synchronise my iTunes library using a software "iSyncr".
    I had the same problem with You because I was using iPhone to listen to music.
    As Our environment is not the same, I can't guarantee that N5ii and iSyncr works but please refer the site below.
    http://www.jrtstudio.com/ja/iSyncr-iTunes-for-Android
  4. MyPants
    I really appreciate how candid and detailed your responses are regarding the business realities of this industry.
  5. Slater91
    That's my thought exactly - what's more, there's something new to learn of how things work and Andy's messages are very clear in this sense. So thank you Andy!
    MyPants likes this.
  6. Metalomaniac
    My Spotify loses downloaded files on the SD, although the files remain on the SD card. No issues with FLACs or MP3s on the same card. I've tried double-reset, downloaded 3k files a dozen times.
    Anyone else having this issue?
  7. CayinSupport
    I have already PM you.
    http://en.cayin.cn/
  8. Andykong
    Thank you very much for the support and recognition. I am not in an Engineering capacity right now so my primarily concern is not technical feasibility or implementation timeline but to make appropriate compromise and achieve win-win whenever possible. This is a very different role from my previous professional duties and I am still learning the tricks. :beerchug:
    http://en.cayin.cn/
    Wyville, seanwee and MyPants like this.
  9. haiku
    Andy, how much burn in do you recommend for the N5ii?
  10. Colors
    Tested it in-store alongside the FiiO X7ii and I’ve decide I’m getting the Cayin N5ii!
    What I liked about it:
    - small form factor
    - nice volume roller
    - premium quality build feel
    - small screen (I like it)
    - decently fast GUI
    - has TIDAL offline (not negotiable)
    - nice clear vocals
    - smooth low end with lush texture
    - small bit of sparkle
    - the numeric volume indicator
    Just small things I liked about. It felt right. Picking it up next Tuesday.
    Signal2Noise, PinkyPowers and cathee like this.
  11. PinkyPowers
    I got to try the X7ii over the weekend. I found it too aggressive and bright. The N5ii is significantly smoother and more musical.
    soundblast75 and Colors like this.
  12. Colors
    How I felt as well.
  13. seanwee
    I mostly agree with you but I wouldn't call the low end of the N5ii lush though. Its more of a powerful and controlled low end
    Colors likes this.
  14. seanwee
    Using which amp module?
  15. Colors
    Ya, sorry, incorrect use of adjective. I should have used “smooth” -> powerful and controlled. That’s my personal definition of lush haha :) (great sensory pleasure)
