Cayin N5ii Android based Master Quality Digital Audio Player
Discussion in 'Portable Source Gear' started by PinkyPowers, Oct 14, 2017.
156 157 158 159 160 161 162 163 164 165
167 168 169 170 171 172 173 174 175 176
  1. seanwee
  2. ElMariachi
  3. Neithan
    Well , decided to give it another go with a different unit.
    Wish me luck :)
  4. Andykong
    Thank you very much for giving N5ii a second chance. :beerchug:
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
    PinkyPowers likes this.
  5. Got2b
    Hi all.
    After update to 3.3 i did one of wipe (didnt remeber wich one) and music stop playing after power on.
    And player always message "music file missing"
    I try double wipe, did update again, even format sd0card and nothing helps. Before it all was cool and autoplay worked.
    [​IMG]
    Any suggestions?
  6. seanwee
    You'll need to rescan the SD card unless you're using folder browser
  7. Ravinder
    Has it been implemented with new software update?
    I want to use a DAP as source in my car feeding digitally to external DAC.
  8. CongoFather
    They solved the major issues in this release. As far as I know, they are working hard on this low-level issue and planning to solve it in the following releases(may be at the end of June)
  9. maira
    Is the amp section class D ?
  10. Got2b
    seanwee, it didnt help. Or i did smt wrong, but it still dont work
  11. CayinSupport
    Base on the last firmware progress report I received, the USB Audio issue is still ongoing. We start to deploy resources back to this issue after we released v3.2en, make some progress but no significant achievement till two weeks ago. Our target is to solve this problem by end of June.
    http://en.cayin.cn/
  12. Ravinder
    Thanks a lot. That was really helpful for me to decide about my DAP purchase.
  13. Metalomaniac
    I get pretty bad static-like interference when there's no music playing and in quiet sections using Spotify. It doesn't happen all the time, though. Is this normal?
    The wifi issue I posted earlier was fixed by connecting to another wifi. Perhaps my friend's wifi is channel 14.
  14. CayinSupport
    I have already PM you.
    http://en.cayin.cn/
  15. seanwee
    I've tested that out and it only happens when the song is loading. It's a pretty normal occurrence actually, I hear interference using my phone too.
