jeffhawke
Check @PinkyPowers post at the very beginning of this thread
that's pretty competitive, do we know what chipsets are used internally?
Mind sharing it? Thanks
I thought it was already in the public domainFor more detail of line out feature of N5ii, I'll publish a functional diagram of N5ii before end of month, we should be able to explain this in more detail later.
How is the battery life?
On page one, it says 'about 12 hours'. That doesn't fill me with confidence that the N5ii will have a very long service life before it can no longer get through a day. I expect to be still using my Plenue D in 10 years time! I'm not up for paying $400 for a device that will be ready for the trash can in 2 years or less.
How much time can I expect playing Red Book FLACS with Wifi OFF and screen mostly OFF using 106dB/mW IEMs?
Shhhhhh!
Now they'll raise the prize!
I wasn't aware a price had been finalized yet.
Stay updated on Cayin at their sponsor profile on Head-Fi.
What's HUS$? "Head-fi US$"?Well, if I get the mathematics right, I assume @Ultrainferno means the N5ii can be priced at HUS$800, am I correct?
An AK70 (MkI or II) has a battery life, as indicated in many reviews, of about 13 hours (as long as you don't stream on WiFi, in which case it's much less). It costs approx. twice as much as the N5II. I don't think anyone would be throwing an AK70 in the trash after 2 years, or an N5II, for that matter...How is the battery life?
One piece of ESS9018K2M as DAC chipset.
Give us sometime and we'll publish a detail design framework. I was told by a trusted reviewer that Cayin is the only DAP brand that will publish a schematic level block diagram, so we are famous for being transparent in our choice of chipsets and components. Cayin believes the implementation and fine tuning is our core competence. We don't mind if a competitor wants to adopt the same set of components because we are confident that they can't achieve the same quality and sound signature.
