Cayin N3Pro DAP: Dual AK4493 and MQA with Vacuum Tube
- Thread starter Andykong
Baten
- Sep 13, 2012
Wow that is very... greenNew case offering over @ Musicteck
https://shop.musicteck.com/products...4&_sid=fbe97d6b6&_ss=r&variant=32480659406910
emilsoft
- Dec 5, 2014
Any comparison vs Fiio M11 Pro and Sony ZX507 - on 4.4mm? Is the N3 Pro's 4.4mm warmer/smoother?
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
The case is very nice quality and fits perfect. It helps that dark green is one of my favorite colours.
morndewey
- Mar 15, 2016
Beginning to really appreciate this dap, particularly its flexibility, ie three sound profilesβable to pair signature with best match for various albums.
Iβd like to revise my comparison to Hiby R5 also. N3pro appears to have more balanced, coherent sound across the spectrum with fewer harsh high frequency peaks.
abitdeef
- Oct 30, 2003
N3p also has a more holographic sound in UL mode.
staticdynamo
"Basically" it is right. Looking only at memory cells, it is right. But memory controller and interface are big differencelol, this place does my head in, you know any sd card is basically a ssd.
between microSD and SSD. So the performances are different.
MicroSDs sound the same as SSDs? I hope it so much. Sometimes try microSDs and dissatisfied with sound quality
and instability. And return to SSDs.
By the way, about optane memory, the memory cell itself is different from normal nand memory. It's 3D XPoint.
No microSDs are made of 3D XPoint.
MichaelLee
Thanks GirakuIf it's not a high pitched noise, it's not microphonic noise.
I got the same problem with my N3Pro. When I turned the volume to zero, I heard some hum noise come and go. Andy suggested to get the service with the seller. Andrew @ MusicTeck quickly replaced my unit. Top notch service.
zobaed11
cayin n3 pro vs hiby 6 pro, which one produces much-balanced output?
Baten
- Sep 13, 2012
Can one of you compare UL vs triode mode?N3p also has a more holographic sound in UL mode.
So as promised, i compared them n8ss in tube mode high gain p+, n3pro high gain ultralinear. Used Anole Vx (all switches off)which will do justice to the daps because of its high resolution less coloration(for my ears).Thank you very much
Songs all flac: Abba Gimme Gimme, Alphaville Big in Japan, Eagles Hotel California, John Williams Revenge of The Sith, Megadeth Tornado of Souls, Metallica Master of Puppets.
I can say that N8 has better soundstage, more airy with better separation and resolution but if you ask me there is no 6x price difference, n3pro is almost there , considering the other totl daps n8 price must be correct but there is something wrong with n3pro pricing
If you have the cash to burn and then some, n8 is the clear choice, if spending that 3299$ will give you nightmares n3pro will not upset you.
morndewey
- Mar 15, 2016
The technology you refer to does not appear to ensure greater, long-term stability of stored data but only how rapidly and reliably most commonly used data is accessed. Iβd like to know if Iβm missing something here"Basically" it is right. Looking only at memory cells, it is right. But memory controller and interface are big difference
jmills8
Previously known as bmiamihk, jmills2
Maybe the Romi mod can help.So as promised, i compared them n8ss in tube mode high gain p+, n3pro high gain ultralinear. Used Anole Vx (all switches off)which will do justice to the daps because of its high resolution less coloration(for my ears).
I can say that N8 is has better soundstage, more airy with better separation and resolution but if you ask me there is no 6x price difference, n3pro is almost there , considering the other totl daps n8 price must be correct but there is something wrong with n3pro pricing
Sorry I didnβt get you, Romi mod will help with what? For me shipment will cost more than the mods
staticdynamo
The thing I'm interested in is if reading speed of data affect the sound quality. Not theoretically but if human sense can differ it.The technology you refer to does not appear to ensure greater, long-term stability of stored data but only how rapidly and reliably most commonly used data is accessed. Iβd like to know if Iβm missing something here
And stability I said is not about data itself, but the stability of data flow from memory(microSD) to dac and amp. I don't know where is the problem.
Contact stability? The speed of interface? I tried to improve it by applying some contact treatment. But I still feel some problems listening to music with microSD.
Maybe it is a prejudice, but I've always felt it.
