NateInBelgium
i've a new IEM a Tin Audio T2 and with N3 is perfect ............... for the price
I'm very pleased to hear this, my Tin Audio T2s are on the way
anybody else having an issue with the N3 losing track of the TF card and having to rescan it ? Mine will be working fine one minute and not have a clue where the SD card is the next. I have to remove the card, reseat it and rescan the library before I can use the player. This hadn't been an issue until recently so not sure if it is a 3.0 firmware thing or a hardware issue.
Mine has been rock-solid for over a year, now.
No problems with mine either.
T2 just the choice for the best earbud for your hearsI'm very pleased to hear this, my Tin Audio T2s are on the way
Stay updated on Cayin at their sponsor profile on Head-Fi.
Hi,
I recently dropped my N3 as I was exiting out of my car and I discovered later on that part of the back became exposed. This is preventing it from turning on. I've tried to plug it in and I get a response from the buttons (they blink) but still no screen. I've tried to open it some more to close it but I'm still noticing that it's still partially opened. Is there a way to close this shut to prevent it from opening again while moved around? Also, I've tried not to open it all the way to prevent anything from coming undone. Does anyone know what could be causing the screen to stay black and not come on?
If I need to reach out to Cayin's technical support, what are my options? info@cayin.cn?
Update: I was able to get the device to turn back on again after hitting the reset button. However, I'm still having trouble getting the device to seal completely. I noticed that one corner had a form of sealant glue on it. What would you recommend I use to keep this sealed shut, super glue?
I have used the Line Out setting with my Cayin N3 to my xDuoo ta-03 tube amp which sits on a little table next to my recliner sofa. Great results. I also use my Opus #1 for that but have no intention of attempting a comparison. Waiting for Hidizs to implement Line Out on the AP200 so I can use that with the tube amp as well.
Amplifier is nothing without good speakerI have used the Line Out setting with my Cayin N3 to my xDuoo ta-03 tube amp which sits on a little table next to my recliner sofa. Great results. I also use my Opus #1 for that but have no intention of attempting a comparison. Waiting for Hidizs to implement Line Out on the AP200 so I can use that with the tube amp as well.
You can not put it in your pocket. Portability is the key.I have used the Line Out setting with my Cayin N3 to my xDuoo ta-03 tube amp which sits on a little table next to my recliner sofa. Great results. I also use my Opus #1 for that but have no intention of attempting a comparison. Waiting for Hidizs to implement Line Out on the AP200 so I can use that with the tube amp as well.
