Cayin N3 Hi-Res DAP with AKM4490 DAC, apt-X Bluetooth, and Line, USB & Coax Out for $150
Discussion in 'Portable Source Gear' started by nmatheis, Jan 31, 2017.
Tags:
351 352 353 354 355 356 357 358 359 360
362 363 364 365 366 367 368 369 370 371
  1. mbwilson111
    I get about 12 hours with that scenario except between 30 and 40 with some headphones.
  2. dacari
    That is my concern, maybe you are lucky and get a perfect unit, I wasn't hoping the max. but an average of 10 hours, what I saw yesterday and this morning I highly doubt. I will wait until two or three cycles of charge and see what happens.
  3. mbwilson111
    I have had mine for 6 months. It is the red one which I believe was introduced after the black and cyan. A month previous I had purchased the cyan one which had issues with the power button Exchanged it in early September. Neither came with a dead battery but I did fully charge before use. I then did the recommended full discharge followed by full recarge a couple of times. Now I just recharge when convenient...usually when it is beteen 10 and 30%...sometimes sooner.
    dacari likes this.
  4. dacari
    Thank you very much for the explanations.
  5. eaglesgift
    I would return it if you can. That was how mine arrived and although it could play 13 hours on a single charge, the battery drained from 100% to 0% in about 5-6 days if I turned it off completely and didn't use it. Lithium batteries should be charged to around 40 or 50% if they are going to be left in storage for any length of time. If they are stored completely flat, they will deteriorate and you have no way of knowing how long that battery had been sitting in a warehouse at 0%.
    mbwilson111 likes this.
  6. dacari
    Lucky you that could reach more than adversited hours!! What you've done, exchange for another one?
  7. eaglesgift
    I only sent it back a few days ago so I don't have a replacement or repair yet. I kept it for 10 months trying to ignore the problem but finally thought I should sort it out before the warranty expired. Yes, getting 13 hours was nice but it is of little use if the battery drains 20% a day when you're not even using it.
  8. jms74
    It still doesn't work on my devices dispite various versions of firmware from cayin and the Android devices I have. Even the hibbylink app has another versions and it still doesn't work.
    I don't know what to do anymore
  9. svil3
    I use hiby music app and hibylink between my cayin n3 and my OnePlus5 (Oxygen OS OB05, Android 8.0.0) and it works normally, yeah sometimes I got a few crashes of the Hiby app, but I think that's the poorly written app itself, since I use the beta version that actually breaks more things that it adds
  10. jms74
    This is driving me insane as i really want this feature working.
    I also noted that i got the same force close (app suddenly stoped working android message) when i try to connect to dropbox on the hibby music app.
  11. jms74
    I found the source of my problem uppong the hibby music app closing uppon connecting to hibbylink.
    Its the Hibby Music language !!!!
    It was set to my default language that's portuguese and now i've tred it setting to english and now it works.
    Please correct the HibbyMusic app to work with other languagues expect english. I mean the HibbyMusic app and not the android settings language. It now works!!
    YEY!!! I'm so happy now.
  12. svil3
    Yeah, that makes sense since I habe english as my default language in mi phone.
    I think that's not Cayin's fault or job, it's Hiby's and they have a nonexistent costumer support, even the app has a thread here in head-fi, and nobody from Hiby answers ever.
  13. LordZero
    What budget amp would you recommend with a balanced output to pair with the f9 pro?
  14. Brooko Contributor
    FiiO's Q1ii
  15. LordZero
    Thanks!Someone said that the q1 amp isn't much greater than the N3, don't know if it's true or not. Also should use the N3 output> Q1i input or N3 usb > Q1i usb?
