Cayin N3 Hi-Res DAP with AKM4490 DAC, apt-X Bluetooth, and Line, USB & Coax Out for $150
Discussion in 'Portable Source Gear' started by nmatheis, Jan 31, 2017.
Tags:
213 214 215 216 217 218 219 220 221 222
224 225 226 227 228 229 230 231 232 233
  1. CayinSupport
    Actually, I am not very clear about "There is a little plastic sticker on the leather back of N3" as I remember there isn't. To get your problem resolved quickly, could you please send us a photo to show it? Thank you in advance!
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
  2. svetlyo
    Here is a picture:
  3. Moodyone
    Mine is the same and starting to look messy now the corners are rolling up. I haven't pealed it off yet, like you I worry it will pull the surface of the Leatherette off, or leave adhesive behind.
    Looking closely there are three lines of text on the sticker. Mostly Chinese writing and some English, Cayin's web address and 5v-2a. Repeating what's printed on the back above.
  4. spoonspoon
    IMG_2637.JPG The earlier you remove it the less chances of leaving any thing behind, btw the sticker not that sticky so it won't do any damage
    ValSilva, Moodyone and eaglesgift like this.
  5. AudioNewbi3
    Hello once again guys,
    So after updating my new Red N3 to FW 2.1, and playing a few albums on it, I have noticed that track orders for albums with 2 disc are completely messed up (when I browse by album after scanning my media library).
    I use foobar to name my music files and if an album has two disc I will name it like so:
    1.01 AAAAA
    1.02 BBBBB
    2.01 CCCCC
    2.02 DDDDD
    Where 1 is the disc number and .01 is the track number from that disc.
    Besides that, how does the N3 sort its music? Alphabetically? When I am trying to browse my music folders in TF Card mode,
    the order would be alphabetical, but then sometimes between artist with english names, my chinese or japanese artist would pop-out even though I use Chinese and Japanese Characters
    Is anyone else having this issue?
    Thank-you
    EDIT: Added "(when I browse by album after scanning my media library)"
  6. jms74
    Hiby Link still closes when establishing a connection to OnePlus 1 with LOS 7.1.2, Oneplus 5 with stock firmware, Nexus 7 2013 with LOS 7.1.2.
    But it works well with XiaoMi RedMi Note 4x Global Version.
    Maybe its a problem with Android 7.xx.xx or LOS with some phones.
    I have a SUGESTION for a future feature:
    Please add a option to set volume to 100 (maximum) when connecting a USB DAC to the N3 and then to the default value when disconnecting the USB DAC. I have to turn it all way up when connecting a USB DAC to the N3 and i almost broke some IEMs when switching from USB DAC to the headphone out because i had volume at 100 and forgot to reduce it.
  7. DBaldock9
    For my file naming, I'm using a dash "-", instead of a period "." between the disc number and track number, and my N3 displays everything in the correct order. Note: I'm not using any characters other than plain English text (no special characters, with accents of any type).
  8. fourrobert13
    As for sorting multiple disc albums, I've yet to find a DAP that does it correctly. I use mp3tag and number the tracks in the other disc in order and combine all discs into one album.
    For example, Metalica - Hardwired to Self-destruct is a 3 CD album. The first two disc had six tracks each and disc three has 13 tracks I think. I combine them all into on album with the tracks 1 through 25, but they are in order and play as they should.
  9. groucho69
    Might be the only way I'd change from C2
  10. AudioNewbi3
    So when you browse them in album mode after scanning media library, the order of the music files is correct when you are using "-" instead of "."?
    That is actually a bloody brilliant idea!!!! Why did it never occur to me. You're a genius!
    Btw, anyone knows if I have scanned my media library, can I remove them (i.e. back to the state when I first got my N3, meaning there is no scanned media library and artist, album, genre list are all blank)?
    If this can only be done through a reset of the player, how should I proceed?
    Thank-you
  11. fourrobert13
    Thanks, but I'm not sure I'm a genius...lol. Just trial and error over the past few years to make it work.
  12. Indrajit
    Hi, the format shows - File system - exFAT. Do i need to change it to FAT32 ?
  13. fish1050
    Yeah I do the same thing with all my multi CD collections as it cuts down on the number of albums to sift through when searching
  14. gLer
    That's a damn good idea...
  15. DBaldock9
    I'm attempting a scan of the music on the memory card in my N3 right now... - ...and after it finished, I checked the Track order on one of my 2-CD Albums.
    It does not list the Tracks in the correct order.
    They're listed by just their Title (which doesn't include the Disc-Track info of the filename).
    The order appears to be:
    Disc2-Track1
    Disc1-Track1
    Disc2-Track2
    Disc1-Track2
    etc.
    I guess I haven't noticed this before, since I normally use the "Browse by Folder" method for accessing my music.
    In the Folder view, the files are listed correctly, by filename (which includes the Disc-Track info at the beginning of the name).
