Asukara
- Dec 17, 2006
It does sound like impedance issueoutput impedance issue?
Yes I am using my Clear and HE-500 out of the balanced outputhave you tried the clear out of balanced?
hi everyone,
i'm considering upgrading to this cayin. i'm currently using gilmore lite mk2 class A amp in SE.
is it worth it? i have auteur, lcd2 and soon ori.
i'm afraid about those saying is bass light and too sparkly.
maybe i should wait and go for gsx mk2 ?
Hi,
I wonder if my unit is faulty but with my Focal Clear I sometimes get some buzzing noise when nothing is playing and other times very loud noise. However it never happens with my HE-500, I'm using the balanced output for both.
The noise stops when I plug the HE-500 but it comes back when I plug the Clear.
Stay updated on Cayin at their sponsor profile on Head-Fi.
@Andykong
I just received my iha 6 tonight. enjoying but waiting for my balanced cables to arrive for my headphones
not sure if i should just stick to my metrum hex dac (that suits me really well) or if i should at all consider the idac 6. I'm thinking there is no need for a second dac and I can use those funds towards perhaps to another headphone
what exactly is the "current" setting on the amp?
is it actually changing current or something close to that?
i'm wondering what that is all about
any insight would be great
also wondering why/how the SE output imp of 10 is so far different from the balanced of .3
isn't that quite unusual?
thanks
peter
I need to find out more detail about your setup and triggers of the noise issue before I can comment:
What is the setting of your iHA-6? H or L gain? High or Low Current? same setting on both headphones? Did the noise change at all when you change the Gain or Current setting?
What is the source of your system? connect to both RCA and XLR input of iHA-6? the noise appear on both inputs?
You said "some buzzing noise when nothing is playing and other times very loud noise", did the noise appeared in roughly the same frequency but with different amplitude? Did you notice any pattern that lead to the different level of noise. The noise will appear immediately when you press the pause or stop button of your player (ie, when nothing is playing)?
I see, so noise and buzzing sound are two independent issues, I thought there are the same thing, my bad.Hi,
Thank you for taking your time
So my iHA is plugged to the iDAC via RCA.
Gain and Current are both set to low and yes, same settings on both headphones.
I haven't tried changing gain or current when noise appear. It happens rarely, maybe 3 times since I bought it (4 months).
Haven't tried connecting the iDAC through XLR.
Yes, noise appeared like you said, same frequency with different amplitude. It appeared even when something is playing but also when the player is off.
The buzzing sound appears way more frequently than the noise, only one side at a time with the Clear. I also tried to turn the iDac off when the buzzing sound appear but nothing changes.
The volume knob doesn't affect the buzzing sound.
I love the stack when it works well, hoping it's nothing serious.
How loud is the buzzing sound? If it happens quite often, please perform one experiment for me: set current to high from now on and keep it for several days, see if this will affect the frequency of the buzzing sound?
