Cayin i5 Lossless Android DAP with AKM4490 DAC supporting 32/384 PCM + 64/128 DSD
post-13803267
Post #3,527 of 3,733
davidcotton
X-CANs and HDAMs
I'm running Neutron on the i5, or do you mean something else?
How is Neutron on the i5? Had a fiio x5iii and returned it (twice, I might add!). Still looking for a decent step up from the sony a35 that I'm using atm and it's really only the lack of gapless on the i5 that made me not consider it.
post-13803290
Post #3,528 of 3,733
Creeepy
Russia Penza
Russia Penza
I contacted the developers of the Neutron. They did several test versions for our DAP. But none of them could provide HI-RES 24/192 ... Here is their final answer:
Hello, Eugene!
Unfortunately there is no good news, they have their own API
AudioTrack. Why they did so is incomprehensible, usually all
customize the implementation of android :: AudioTrack and beyond. All the less
The well-known DAPs go exactly this way, so they turned out
hi-res.
In theory, they should wrap their implementation in android :: AudioTrack
interface and make the firmware update, then there will be an opportunity
output to hi-res similarly as on other devices.
Yours faithfully,
Dmitriy.
post-13803341
Post #3,529 of 3,733
JaeYoon
Singapore
Singapore
That sucks guys for real. Sorry neutron will not be able to implement it.
Luckily for me, 16/44 is max I'm willing to listen to. Cd quality is at my hearings limit.
For those of you who need 24 bit hi res. Thats a letdown.
Reactions: frost15
post-13804567
Post #3,530 of 3,733
Seems to be pretty stable
Seems to work pretty well on the i5. Has both gapless and replay gain - so thats enough reason for me to use it over the Hiby interface. Also has some nice DSP tools which are quite cool for widening staging.
Reactions: JaeYoon
post-13804926
Post #3,531 of 3,733
bluedolphin
Why does Cayin i5 Hibyplayer dont allow Short songs.
I now have a full Live album where first track is 0:57 thats the preludium with opening music
it should be the whole album.
This happen with ALL music i transfer if the song is under 1 minute long.
it only happen in Hibyplayer not in Neutron and poweramp.
After i have transfered song to Cayin i5, i go into hibyplayer and check the album
what do i see first song of the album dont show up, is there i know is there
because it show up in Poweramp and Neutron
And is NOT that is not properly tagged is because is under 1 minute long
Is there a way around this?
I dont like album to always start on song nr.2
This is not aceptable for me.
I like to get help on this
thank you
Please try it yourself try to transfer songs under 1 minute
and see that it wont show up in hibymusic
it must be the first song on the album
post-13804937
Post #3,532 of 3,733
frost15
Spain
Spain
thank you
Easily fixable by going to scan options. There is an option there to make Hiby Scan any track with less than 60 seconds too.
post-13804962
Post #3,533 of 3,733
bluedolphin
thanks could you be more specific under music scan in hibymusic i have 2 option scan all and scan specified folder there is not this under 60 seconds option
then i have music settings in hiby but there i dont see it
post-13804998
Post #3,534 of 3,733
bluedolphin
Frost15 Thank you very much
i found it now
is in hibymusic under music scan
i didnt see at first the little wheel at top i clicked on it
and disabled this
skipped music files under 60 seconds.
It was turned on by default to skip songs under 60 seconds (it is better that is disabled by default)
Now all my songs under 60 seconds show up in All albums
What a Joy
Thank you
Reactions: JaeYoon
post-13812784
Post #3,536 of 3,733
smy1
USA
USA
post-13812819
Post #3,538 of 3,733
smy1
USA
USA
Reactions: JaeYoon
post-13812832
Post #3,539 of 3,733
JaeYoon
Singapore
Singapore
me too. I got the Athena Adel MAM
:D yay!!! I can say it's rare to find another athena wearer!!!
I was told by Jackpot the Athena is way too close to Zeus. Just musicality and warmth.
I didn't think it was worth for me to spend 2 grand on Zeus. I think Athena is a seriously great deal for it's price. Zeus is worth definitely for those who want every last ounce that can be squeezed out of Empire Ears and are willing throw another 1.5k+ for a very small upgrade in technicality and upper ranges. Very intense critical listening needed.
Reactions: smy1
post-13813183
Post #3,540 of 3,733
smy1
USA
USA
Some guy said the Athena is better then the Zeus to his ears and also i think the mids are better on the Athena then the Zeus.
Reactions: JaeYoon
