Cayin i5 Lossless Android DAP with AKM4490 DAC supporting 32/384 PCM + 64/128 DSD
Discussion in 'Portable Source Gear' started by nmatheis, Mar 21, 2016.
Tags:
208 209 210 211 212 213 214 215 216 217
219 220 221 222 223 224 225 226 227 228
  1. Andykong
    What version of Windows? We have been informed that the latest Windows 10 updated has changed the USB Audio setting and causing a lot of problem with existing USB Audio drivers. If you are updated your WIndows 10 to the latest version, then you might need to fall back to our previous version of USB driver, but please remember to disable Driver Signature Enforcement when you install the old version.
    Other then that, if you are using the Windows 7,8, 8.1 and other version of Windows 10, you can install our Universal USB Driver, this should be straight forward and we have provided instruction in the download page for your reference.
    http://en.cayin.cn/download/show?id=13481
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
  2. markoul80
    Thanks AndyKong for your interest, I appreciate. I spent something like an hour or more today with Technical online Support from Cayin, but this didn't solve the problem. I am on Windows 7 and I downloaded and installed the Universal USB Driver from same link as provided by you in above post. There remains to find if something is wrong with my laptop..I think the only way to find is by trying to connect to someone else's computer...thnx
  3. Alexei23
    Hi guys. I have just returned my second ibasso dx80 (a very good dap i think) and have recieved a refund and am considering other daps as well as another dx80. I was wondering what deal was with the Cayin i5 it looks good, has lots of features and i'm told sounds good, but I have also heard that it is very buggy! Which puts me off. The only problem I have with the DX80 is buggy firmware, the fact I have had to return two of them and the lack of bluetooth. I am also consider the Astell & Kern AK70, but spending an extra £100 over the i5 and £200 over the DX80, in not so sure about.
    1. As I intend for the next dap i get to be my day to day use without a separate headphone amp, what is the lowdown with the i5 in regards to reliability and bugs.
    2. Is there any owners of both the i5 and either a DX80 or AK70 that can give me some insight on the advantages and disadvantages of the daps in relation to each other.
    3. How happy are you Cayin i5 owners with the dap?
  4. Ziggomatic
    I got the i5 to replace my DX80, which I lost on the bus (still upset at myself about that one). Based on my experience, I would say most of the complaints about bugs with the i5 relate to bluetooth and streaming functionality. I don't normally use those features - I mostly use it as a straight-up DAP. Used in that way, I haven't had very many problems with it - much less firmware problems than the DX80 (though iBasso was pretty good about fixing bugs while I had it), and the firmware in general provides a better user experience (in my opinion). To me, as far as usability and ergonomics go, the i5 is a clear upgrade over the DX80.
    I like the sound of the i5 better, too. It's a little warmer, but the bass is better (more extended and textured) and the sound in general is more refined and reveals more detail. I thought the DX80 was really dynamic, with some great punch, but to my ears (and memory - I never had a chance to compare them) it's not a refined sound compared to the i5.
    Hope that helps.
  5. Ziggomatic
    I should add that one of the things you probably won't like about the i5 coming from the DX80 is the single microSD slot. Kind of a bummer, but I was able to get over it with a 200gb card.
  6. Alexei23
    It does help thanks. I am starting to lean towards i5 as a result. So long as it has an SD card slot I'm satisfied as it does have a little built in capacity.
    In regards the the bluetooth issues, do you happen to know anything about that?
  7. Ziggomatic
    I'd hate to comment on it, since I've never really used that feature. There are posts about the bluetooth functionality in this thread, though.
  8. Alexei23
    Well i've ordered the i5. Do you guys have any advice regarding firmware and the problems with the latest version.?
  9. bluedolphin
    Can someone tell me where to buy the Blue Cayin i5 Leather case
    a guy in Japan got in somewhere is in japanesee
    [​IMG]
    [​IMG]
  10. JaeYoon
    Lucky for you! I can speak/read Japanese!
    The twitter member below asked where to buy, the original poster mentioned Ebay the
    A6 EASECASE Custom-Made Genuine Leather Case For CAYIN I5
    You can also pick and choose the colors of the leather on the Ebay Storepage down at the bottom so don't click buy right away!!
    https://tinyurl.com/cayini5bluecase
  11. bluedolphin
    Thanks
    JaeYoon likes this.
  12. JaeYoon
    -edit no prob!
  13. pr0b3r
    Check here as well: Valentinum Leather cases
    They also offer cases for various DAPs and phones in different color options.
    [​IMG]
    [​IMG] [​IMG]
    bluedolphin and JaeYoon like this.
  14. JaeYoon
    those look really nice!!!
  15. bluedolphin
    Is the Brown First Cayin i5 case still sold or discontinued i cant find it anywhere?
    i only find the new Grey
    [​IMG]
