Cayin i5 Lossless Android DAP with AKM4490 DAC supporting 32/384 PCM + 64/128 DSD
Discussion in 'Portable Source Gear' started by nmatheis, Mar 21, 2016.
Tags:
203 204 205 206 207 208 209 210 211 212
214 215 216 217 218 219 220 221 222 223
  1. BartSimpson1976
    Highly interesting...I had either in most cases an audible gap or if there is no gap the next song was slightly cut off in the beginning.
    Something which doesn't sound right when listening to live albums. Few worked perfectly, but absolutely no clue why some had problems
    and some not.
  2. pr0b3r
    Yeah, same thing I observed. I didn't care much about the feature since I seldom listen straight from an album, but now that I tried it, the feature is working but not 100% as it should. Maybe we can raise this to @Andykong to inform the team.
  3. BartSimpson1976
    It has been raised since the player was released!
  4. pr0b3r
    Now it's becoming more obvious how oblivious I was about this feature. Haha!
  5. BartSimpson1976
    well, if you have a lot of live albums in your collection you will find that proper gapless is nearly the most important thing.
    And it is so hard to understand why the AndroidApp on which the stock player is based on can do this without issues on your phone while a dedicated DAP cannot!
  6. pr0b3r
    Possible answer could be that the HibyMusic app was originally developed and intended for smartphone use, and modifying it for the i5 use wasn't executed flawlessly. You're aware that the OS of the i5 is a heavily modified android, right? Perhaps that's the reason. They should develop a software that is intended and solely designed for the structure of the i5.
  7. BrianD19
    That's different behaviour compared to mine.
    When using 'random track' it would cut the last couple of seconds of a track when going to the next, which is very annoying.
    As far as a gap goes between tracks, it was clearly audible.
  8. gannjunior
    Hi,
    any known issue with line out?
    just arrived me the i5. Updated to 2.2 fw.
    my other gears: fiio x3 2nd, oppo Pm-3, hifiman he-560, fiio E12 DIY with muses02.
    The E12diy incredibly boost the x3 2nd giving him more body.
    Despite of my expectations, the combination i5+e12diy(line out)+heaphones is quite poor compared to x3II: power is missing and I really don't understand how it can be possible.
    While using the internal dac no problem.
  9. BartSimpson1976
    Totally aware. But a designated DAP should have proper gapless a a basic function. Ok, it didn't work on release so after some firmware updates it should be ok. But after nearly one year it still isn't. If you launch a DAP you should be aware of the requirements of your targeted customer group.
  10. pr0b3r
    I agree on this though. It should have been solved early on. This is probably easier to fix compared to the sound cut problems that other DAPs are having right now.
  11. davixx500
    hey guys I got the fiio x5 3rd gen and I am not too happy with it, many bugs, slow, apps crashing, spotify deleting offline songs whenever you reboot, Equalizer doesn't work at all on spotify so I am debating on getting the cayin i5. My question is are the devs still active since it is a year old ? do they still release new firmware updates or has it slowed down ?
  12. Joseph Lin
    I don't think they are. No response from representatives anymore. So sad, less than one year old and it is abandoned. Promised features are not fulfilled...
  13. frost15
    That's what pissing me off... How can such a young device be abandoned by its creators and representatives so soon? I hope they are just taking a break. I mean, as I said the list of things that should get a fix asap is small, it should not be such a problem!
  14. BartSimpson1976
    an i5 2nd gen in same appearance with second MicroSD slot, real USB-C, polished UI and AptX HD would be close to being the perfect DAP.
    heliosphann likes this.
  15. JaeYoon
    This is sad since I love Cayin N5 and wanted i5 someday. But then this happened no support i5 it looks like.
