Cayin i5 Lossless Android DAP with AKM4490 DAC supporting 32/384 PCM + 64/128 DSD
Discussion in 'Portable Source Gear' started by nmatheis, Mar 21, 2016.
Tags:
199 200 201 202 203 204 205 206 207 208
210 211 212 213 214 215 216 217 218 219
  1. archigius
    I bought the i5 to use it with my Westone W60, and the pairing is magnificent!
    Now i'm trying to use the Cayin with my Mojo, but with no luck.
    I have an OTG adapter and, although the Mojo seems to accept the signal (red light on), no sound comes from the Chord.
    So i tried the Onkyo Player and it works fine, but with the Cayin app it doesn't.
    I could use the Onkyo app, but there is no folder navigation...[​IMG]
  2. BartSimpson1976
    waiting for firmware with proper sorting, gapless, replay gain....
  3. smy1
    It happens to you too?
  4. frost15
    Only once.
  5. archigius
    I did more tests with USB audio. With Cayin app, Usb Audio Player Pro and Onkio Player i can hear some clics during music reproduction. That's very annoying and makes it unusable with my Mojo. Wonder if the Cayin usb to spdif works better...
  6. professor55
  7. PinkyPowers
    With that setup, you have achieved audio perfection. It's SOOOO good!
    professor55 likes this.
  8. georgelai57
    Hi,
    Can this do USB-C OTG and is it reliable or hit-and-miss?
    Thanks.
  9. heliosphann
    I've got a NAS drive on my network and I'm trying to play FLAC files off of it with my i5. I can navigate the menu's and get to the files, but when I try to play one I get an error/crash message everytime.
    Any thoughts on this?
  10. Joseph Lin
    It does not work? Just a gimmick?
  11. Ziggomatic
    Here's a weird issue: I just got a used Beyer DT 770 PRO 250 off of eBay. Unfortunately, the headphones are defective. When I tested them on my phone and laptop, the left channel didn't work at all.
    Strangely, when I try to listen with my i5, no sound is produced at all. However, when I placed the jack in the line-out (out of curiosity), the right channel played only (just like with my phone and laptop). I'm sending the headphones back, but I just had no idea why it wouldn't play at all out of the headphone jack on the i5. Any ideas? Just curious...
  12. nmatheis Contributor
    Here's an update from my YouTube channel on some DAPs I've been enjoying recently, including the Cayin i5...
    Kavalier likes this.
  13. archigius
    Hi, otg works flawlessly with sd cards, but it seems not perfectly working with an external usb dac. I'm trying to use the i5 with my Mojo but i can hear some small clics during reproduction.
    I know that we have a Cayin guy here, i'm curious to know what he thinks about this. I tried both with an otg adapter and a usb-C to usb micro cable, same results. I'm not happy with this.
    georgelai57 likes this.
  14. heliosphann
    So I got TIDAL working flawlessly on the i5! I decided to try using USB Audio Player as I use it with my tablet/Tidal/Mojo setup and wouldn't you know, works amazing! Not stuttering at all. Also streaming over my network works fantastic. Really jazzed about this!
  15. nmatheis Contributor
    As in you're routing Tidal through UAPP? Either way, yes or no can you please explain in a bit more detail?
