Cayin i5 Lossless Android DAP with AKM4490 DAC supporting 32/384 PCM + 64/128 DSD
Discussion in 'Portable Source Gear' started by nmatheis, Mar 21, 2016.
Tags:
182 183 184 185 186 187 188 189 190 191
193 194 195 196 197 198 199 200 201 202
  1. professor55
    I've used it in my Ford Expedition with Sync, and it works. It was kind of finicky at first, but it works.
  2. smy1
    Mm I drive a corolla 2016 model if anybody drives one and knows how to.
  3. raykkho
    Agree why DNS setting would affect offline Tidal playback.
    My Tidal playback is essentially entirely offline for their HiFi content, and my finding is that NOT every albums I downloaded has stuttering problem, one or two I have downloaded recently were entirely stutter free and in fact sounded very nice, while other downloads were so full of stutters, rendering them unlistenable. [​IMG]
  4. Andykong
    Not sure if this is related, but the bitrate of lossless 16/44.1 can ranged from 5xx bps to well over 1000 bps, some of the HiFi tracks at lower bit rate might cause less pressure to the CPU loading.
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
  5. Andykong
    When subscriber contact Tidal and kind of "complaint" about the stuttering problem, he is entitled to Customer support service and handled by properly trained CS staff. When I contact Tidal, I am not their customer, and my questions probably will be redirected to technical service or corporate liaison function, not surprised that the efficiency and service commitment are very different.
    We learned a lot from the i5 project, and we definitely can position ourselves better in our next attempt. To tell you the truth, the i5 will possibly be an one-off entry for a long time, we probably will not commit to DAP with Google Play again in foreseeable future. The fact that Google Play is NOT available in mainland China has make life very difficult to our software development team.
    http://en.cayin.cn/
  6. Andykong
    When you said the DAC got no signal after the connection, I assume you men i5 got no signal after the connection?
    I have checked out the Cambridge Audio 851N briefly, apparently this player only provide digital out from its coaxial and Toslink connections (maybe the AES/EBU on top right corner as well). The USB ports on top left are probably designed for "storage" purpose. There is a USB-B connectors but that is marked as USB Audio INPUT only.
    Please check with Cambridge Audio if 851N supports USB Audio output, and ask if they have setup or special instruction to enable this function.
    http://en.cayin.cn/
  7. NGGG
    For other devices (including mobile) which works OK, I connect to the "USB Audio In" near the bottom right-hand corner of your photo.
  8. Andykong
    The domestic (Chinese) version firmware is located at our web-server in Mainland China, and from what I understand, most Internet Service Providers won't devote a lot of resource to build a data backbone to and from China, so the connection is kind of unreliable.
    For the benefit of our oversee users, we have established an off-shore service to host the International version firmware in Hong Kong, so you should have similar problem with the International version firmware. If anyone wants to try out the domestic version firmware, you can contact me by PM, and I'll download the firmware and put it up on my Google drive for short term.
    http://en.cayin.cn/
  9. kel77
    On Cayin i5, make sure you set Connect Mode to USB mode.
    There are USB, MTP and DAC modes as well.
  10. Andykong
    You are quite right that this most of the system crash in android are related to memory management issue. My i5 does crash occasionally, by occasionally I mean roughly one to two times per week.
    Base on my personal experience, installing more third party application does increase the frequency of system crash. I don't know for sure but one of the Android customization of i5 related to the memory structure: the internal memory of i5 are split into 4GB system + 32GB Data. this might introduce incompatibility to certain app or hidden background tasks, especially the latter which are normally hidden in the system memory. This is a design that improve the performance of the stock HiBy Music Player and Cayin has put priority on native playback over compatibility of third party applications.
    http://en.cayin.cn/
  11. Andykong
    What is the resolution of your album art files? i5 has suggested resolution upto 1000x1000 in our specification. Higher resolution might works, but will become unstable occasionally.
    http://en.cayin.cn/
    frost15 likes this.
  12. Andykong
    That's a very good start, looking forward to a detail impression.
    By the way, I was a DX100 user, hang on with DX100 for a long time and finally replaced that by N6, and that's how I hooked up with Cayin. Although I don't have the DX100 to compare side by side right now, but the DX100 does offer better sound quality when compare with i5 base on my memory. By the way, the designer of DX100 has developed a new ES9018 based DAP recently, check out the Oriolus DP100 if you had the opportunity, probably not exactly your expected DX100 successor but it certainly worth checking out.
    http://en.cayin.cn/
  13. Andykong
    ipod touch 6 + Chord mojo, that's not a popular transport by today's standard, but I think it'll work very well sounds very good for the price. I guess if you are not interested in Hi-Res or DSD experience, the Cayin i5 probably won't offer better sound quality then your current stack, but it will sound very different, to a level that you probably need some time to adjust to it. Check out Glassmonky's review (#Audio Quality) or our previous discussion on this topic, this will give you some insight to the sound signature of i5 DAP.
    But if you are looking for an alternative from lightweight and versatile perspective, then i5 should perform very well under these headings. :beerchug:
    http://en.cayin.cn/
  14. Andykong
    The Cambridge Audio 851N has built-in DAC, the USB Audio in connector will accept USB digital signal INTO the network work and decode it with its internal DAC, it won't, theoretically, output USB Audio signal from that connector, that's why the i5 is not responding, because there is no audio bit-stream coming from Cambridge Audio 851N to Cayin i5 with the way you connected.
    http://en.cayin.cn/
  15. NGGG
    I think I have misunderstood the function of the new firmware. Is it that i5 cannot be digital source for the music to be played through an external DAC via USB connection?
