4/5 Rating [Design]
4.5/5 Rating [Battery Life]
^ When the i5's screen turns off, it has this kind of retro TV shut down animation. Small things like this in the i5's graphical user interface make it noteworthy, in a good way, since nothing appears to be stock Android in the software and it makes for a unique experience for the user.
The only really big gripe I have for the i5 is its weight. This thing is like a brick both in terms of its size and its mass. The size I don't mind too much as it fits in my pocket just fine, but the weight does feel odd. In your hand, I found the i5 to be a bit top-heavy, presumably because of the volume knob(?).
Although I give a thumbs up to the direction of using USB C for devices, it hasn't quite been widely adopted yet, so if you lose the included USB C cable, you're likely stuck having to buy another cable. One thing I don't like about the USB DAC implementation is the
asynchronous USB buffer: it seems to delay audio by 0.5-1 second when playing a regular video or audio stream, which means this device also isn't completely ideal if you're working on something that requires precise audio timing such as editing audio and/or video.
Outside of these things, the i5 feels really rock-solid in terms of build. As mentioned before, the physical media buttons are easy to access and the volume knob's resistance makes it nice to prevent large accidental volume changes when in a pocket.
Although this is just my opinion, I think the carbon fiber (and carbon fiber on consumer electronics in general) on the back looks a bit tacky. A pure black backing would have looked a lot nicer to me, like the Questyle QP1R (simple and sleek).
In terms of the battery life, I never did a complete battery drain. I did manage to get around 5 hours of playback during one listening session and there was about 60% battery left before I started to charge it, so the rated 11 hours of playback seems reasonable to extrapolate, which is very reasonable.
While I had the i5 in my pocket, the device did not become super warm when playing PCM, which is good to see. I've encountered a few portable media players that get uncomfortably warm in my pocket.
