dpump
- Jun 23, 2001
Regarding the noise issues being discussed here. When you want to test any amp to see if the amp is generating noise itself, you cannot, repeat cannot, unplug all inputs, connect headphones, and then turn up the volume. You need to have shorting plugs in the inputs you are testing. An open or unloaded input will always cause you to hear more noise than the amp is generating by itself. I'm very surprised Andy Kong and Cayin haven't mentioned this. You need RCA shorting plugs and XLR shorting plugs to do the noise tests you are performing to be sure hiss is coming just from the amp.
Another thing is the impedance and sensitivity of the headphones you are using. Unfortunately, in my view, there has been a race by manufacturers in recent years to make their headphones or iems more and more efficient so they can claim that any source from a computer, phone, dap, portable amp, etc, can properly drive their phones. When you connect higher sensitivity and/or low impedance phones you will hear more noise. Connect a 93dB headphone and you have little to no noise. Connect a 100dB headphone and, no surprise, you hear more noise. Iems often go up to 110dB sensitivity or more so can be unusable on many amps due to noise. You have to take into consideration the specifications of the phones you are using when you are testing any amp for noise.
High and higher output power from headphone amps. There also seems to be the expectation now that amps should have as much output power as possible. We're up to 3 watts, 5 watts, 8 watts and more. There are almost no headphones that need this kind of power. The more power you have from an amp, especially tube amps, the more noise you can have. To some extent, you can't have a lot of power on a tube amp and expect to hear no noise of any kind. Tube amps will almost have more noise than solid state amps, although lower power tube amps can often be very quiet.
Bottom line, you should expect to hear some noise from Cayin amps using KT88, EL34, 300B, and EL84 power tubes when they have been designed to output multiple watts of power. These output tubes were originally designed and used to power speakers before headphones were even in use the way we are using them. All of these can be great sounding tubes, but in some sense are being used outside of the use they were designed for. I own a number of tube headphone amps, including the Cayin HA-1A MK2. My Cayin does have some hiss and noise with high impedance/high sensitivity headphones, but almost none with lower impedance phones. Other amps I have with less than 1 watt output have little noise. So don't expect to have no noise on a higher power tube amp. Tubes are inherently noisier than solid state and designing a tube headphone amp with a high output level, no matter what power tubes are being used, will pretty much guarantee you will have some audible noise depending on the headphones you are using.
I'm not saying that there might not be something in the design of the Cayin amps that is causing some of the noise. That may be the case. A possible fix could be to lower the gain somewhere in the amp, but I tend to think the Cayin is designed for the best possible sound and some noise is a result of their design choices. It will be interesting to see if Cayin makes any design changes and then discusses them here so owners can decide if they want to make any changes themselves.
