Cavalli Audio Stacker ll
Type
For Sale
Currency
Euro
Price
680
Shipping Destinations
Anywhere
Or Best Offer
Yes
post-15111639
Thread Starter
Post #1 of 1
Sweden
Stockholm
Stockholm
This is a very rare high-end amp, with only a handful ever made. The Cavalli Audio Stacker II hybrid amp, the predecessor to the Liquid Glass.
The amp was specially designed and built to drive orthodynamic headphones, but works with many other headphones as well.
Some of its features includes.
  1. a brand new broskie high voltage power supply at 275Volts
  2. fresh build and brand new case
  3. green LED light around the power button
  4. AmpOhm 0.22uF Aluminum foil PIO coupling caps
  5. Toshiba 2SC2238/2SA968 output devices in the buffer
  6. TKD 2CP-2511 potentiometer
  7. Vampire RCA jacks with loop out.
  8. Schaffner filtered AC inlet
  9. Can run 6.3 volt novals (6CG7, 6GU7, 5814) OR Octals (6SN7) tubes in the input stage
  10. 3 sets of tubes included: -
  11. matched 6CG7 rca clear tops
    2 RCA 6GU7 black tops
    2 RCA 6FQ7/6CG7 clear tops
Dimensions are 41.5 cm depth, 41 cm wide and 14 cm tall so it's quite a beast of a head amp. This unit runs on US voltage. Can include my step down transformer for a reasonable amount if you are living in Euope.
680€ + shipping + PP fees
Reactions: Killercrush
