Joshatdot
I have a 91 Accord LX, 4 Door, 5 Speed. The alternator went out as I was driving on the freeway. I didn't know it at the time, but the engine started to misfire and jerky for a few seconds (about 5~10 sec). It was early in the morning and raining, so I had the wipers on delay & all lights on.
A few minutes later I noticed the wipers were jerky/skippy, and I turned off the main lights & left the running lights on, and the wipers were fine (I didn't think that the alt was out at this time).
I got home, and took a shower and went to my car to goto work. *click* *click* *click*...dead battery. After work, I went to NAPA to test the alt, and it was not charging (volt meter was reading 9.1 volts!). It soon died while I was at NAPA.
I got a new alt there, re-manufactured OEM 80amp, got the batt quick charged to 12v to start it and get me home. My dad got me a Black & Decker Smart 2-4-6amp battery charger from ACE Hardware, and charged my battery.
I drove to my friend house to work on my car, during the day so very limited battery drain. So we got down & dirty yo change my Alt. It wasn't as EZ as it was on my dads old Ford F250. We had to remove the PS pump to get to the Alt, finagle with odd angles with the ratchet to get to some bolts. Anywho, we got'er done, and it WAS charging at 14.3 volts at idle, nothing on.
As I was driving home, I had to speed up to pass a car on a two lane country road. I down shifted from 4th to 3rd, and speed the engine to about 5000 RPM. I noticed that the lights went slightly dim, and when I was slowing down and the engine went below 1500 RPM the BATT light went on. The BATT light did go off when above 1500 RPM.
When I got home, I checked the batt's voltage with nothing on, it was 12.7 volts. When I started the car, it was the same voltage & stayed the same even if I revved the RPMs above 1500. I let the engine run at idle till it was warmed up, checking various wires & stuff, voltages, etc.
I turned off the car, did some Google searching for a while. I went to start the car to goto NAPA to test the Alt & batt.
...the engine was just turning over & over & over. This happened afew times before. I would usually leave the key ON for a while and try to start the car.
This would usually work, at first it would sputter and stop. Try to start again, it would sputter abit more and stop. 3rd time it would start like normal.
But this time, it would not sputter/run enuff to keep it running, and eventually I ran the battery down.
SOOOOO...
1. I need to check the Alt & batt to see if they are ok?
2. Is the 1500 RPM a bad battery or bad Alt?
3. Is there a Alt fuse? I did not see one in the Main box or under the Dash box.
4. Should I replace my Fuel filter?
5. or is it the Main Relay thats bad?
6. Maybe failing Fuel pump?
SOOOOO...
