Can someone help me to decide between two headphones?
Aug 26, 2015 at 4:24 PM Thread Starter Post #1 of 7
vorlex
I don't know much about headphones at all. These are the same price so thats not a factor. I just need help picking the best one out of the two, meaning best sound mainly. Here are the names and specs of the two sets. Isolation doesn't really matter to me I just need one that will have a clear sound and will display every sound/instrument smoothly and clearly without any static or sounding muffled.
Bluedio Bluetooth 4.1 Headset Turbine Hurricane H
Specs:
Drivers: 57mm Speaker
Transducer Type: Dynamic
Bluetooth Version: V4.1
Frequency Range: 2.4GHz-2.48GHz
Operating distance: up to 10m (Free Space)
Bluetooth profiles: A2DP,AVRCP,HSP,HFP
Impedance: 16?
Frequency response: 20Hz-20kHz
Sensitivity: 110dB
Distortion:<0.1%(THD)
Music playtime: up to 40 hours
Talk time: up to 45 hours
Standby time: up to 1625 hours
Charging time: about 2 hours
Operational temperature: -10 to 50°C
Ear padding material: pleather
or the...
Audio-Technica ATH-WS55IBK Solid Bass Over-Ear Headset (not bluetooth)
Specs:
Type    Closed-back Dynamic
Driver Diameter    40 mm
Frequency Response    10 - 24,000 Hz
Maximum Input Power    500 mW
Sensitivity    100 dB/mW
Impedance    40 ohms
Weight    165 g
Cable    1.2 m (3.9'), Y-type
Connector    3.5mm (1/8") L-type, mini-stereo, gold-plated
Type (Microphone)    Condenser
Sensitivity (Microphone)    -44dB (0dB = 1V/Pa, 1kHz)
Frequency Response (Microphone)    100 - 10,000 Hz
Polar Pattern (Microphone)    Omnidirectional
Aug 26, 2015 at 4:57 PM Post #2 of 7
Can you get the Takstar Pro 80 or Gemini HSR-1000 instead?
Aug 26, 2015 at 5:26 PM Post #4 of 7
  I think I might go for the Gemini HSR-1000, not that it really matters but these look like they completely cover your ear, do they?
Yes, they are Over-Ear style.
Aug 26, 2015 at 5:32 PM Post #6 of 7
  Purchasing them now thanks for the recommendations. I appreciate it man.
You're welcome! Have fun!
Aug 26, 2015 at 9:23 PM Post #7 of 7
To me the Gemini HSR-1000 are really about the best bang for the buck headphones you can get.
And they usually sell for under $50 at Amazon.
I would think if Sony put their name on them they would easily sell for over $125.
