Harty
- Aug 2, 2003
I've finally found a solution to fitting the new HD 800 replacement Ear Pads.
A lot of people can't get the HD800 Ear Pads to lock onto the HD800 frame, this is because the white plastic membrane is too tight around the new replacement HD800 Ear Pads D frame.
Only do this below if you can’t get the new HD800 replacement Ear Pads to fit onto the HD800.
Simply put two fingers in between the black plastic ear pad D ring and the white plastic membrane of the new HD800 replacement earpads, obviously finger print side pointing up and touching the underside of the white plastic membrane, then place your two thumbs, one each on top of the white plastic membrane pressing down on top of the white plastic membrane and your two fingers underneath, pull and stretch apart the white plastic membrane between each finger and thumb following the D shape all around the black plastic ear pad ring, do this several times around the D pad to loosen up the white plastic membrane, don't be too gentle, the plastic has a lot of stretch in it, only stretch around the ear pad D shape and not towards the center hole of the D frame.
Then simply press the ear pads down onto the HD800 chamber black frame to click and lock down into place.
Best wishes,
Paul.
Best wishes,
Paul.
