Campfire - Solaris
367 368 369 370 371 372 373 374 375 376
378 379 380 381 382 383 384 385 386 387
  1. BananaOoyoo
    The tips I used were silicone, narrow bore tips. I try to avoid foamies when possible, since I find that they dumb down the sound by killing treble and boosting midbass.
    When they're officially available in Korea, I'll make sure to bring my eartips with me and try them all. Unfortuately, I highly doubt I'll get a good fit with wider bore tips (Spiral Dots, SymbioW, Sedna, etc.) given the shape of my ears.
  2. fokta
    Sorry, what I mean, widebore is the bore diameter inside... atleast the same diameter wide as the Noozle...
    even I use regular Silicon tips with big bore diameter from TFZ... the bore size perfectly fits
    cr3ativ3 likes this.
  3. cr3ativ3
    this is how it should look like :)
  4. ExpatinJapan
    Posted in the Andromeda thread and probably relevant here.
    @audio123
    Physical differences are the inner core/stem is color coded on the ++.
    It also seems to be slightly firmer and and have a better lip to grip the IEM nozzle for a better seal.
    The ++ outer is more a smoother matt and soft feeling (but still firm) finish, whilst the original has a more shiny harder surface.
    The original has good body when a correct seal is achieved with a slight V.
    The ++ has more mids.
    @audio123 care to weigh in?
    [​IMG]
    [​IMG]
    As can be seen above the size is generally the same. The bore opening is generally the same if not identical.
    [​IMG]
    Above a comparison to the (original) Andromeda Silicone tips - not sure if they have changed. And the original JVC spiral Dots.
  5. cr3ativ3
    The ++ spirals are much to expensive here in Germany ... over 50 euro for 2 pairs ..: no .. maybe after sometime the price will settle here ..:
  6. ExpatinJapan
    yeah the price is pretty crazy here too
    ¥2,420 - ¥2,700 or there abouts...
  7. MaxD
    Whoever recommended the Spiral Dot's with the Symbio foams, Thank You. Brilliant idea and it made so much difference.
    I have an idea to share too. I am conscious about loosing one of my earphones when they are hanging around my neck, just being held by one connector. My solution is to put M3 duel lock on the backs. I normally use it for putting amps on the back of phones or daps. It works well, they clip together nicely too. I suppose it covers the gold but I don't mind that and the added security sets my mind at rest :)
    fokta likes this.
  8. cr3ativ3
    You’re welcome , was my idea :) i love it too
  9. cr3ativ3
    If google is right , it would be around 21 euro ...
    ExpatinJapan likes this.
  10. subguy812
    To buy Spiral Dot ++ on eBay and have them shipped from Japan equates to about $58.00, I am not going down that path anytime soon. What the introduction of the new tip has done is increased the availability of the original and I can now get them for under $13.00 for the pack of 6.
  11. cr3ativ3
    Do you have a link with this Price ??
  12. subguy812
  13. cr3ativ3
  14. cr3ativ3
  15. subguy812
    Yes the original ones...
