Campfire - Solaris
365 366 367 368 369 370 371 372 373 374
376 377 378 379 380 381 382 383 384 385
  1. subguy812
    It is a toss up between the QP2R and QA-361. With the QA-361 getting the nod.
  2. Rockwell75
    The QP2R sounded great but I found its interface (physical and software) so clunky that it would drive me absolutely bonkers if it was my only DAP.
  3. ExpatinJapan
    Yep.
    Its an important point and one i was thinking about the other day.
    Nice low volume but still excellent dynamics.
    Hearing saved!
    fokta likes this.
  4. subguy812
    If you aren't familiar with the QA-361, do some research.
    I have a review I am currently working on and then this jewel is next.
  5. Wildcatsare1
    Wide bore tips work better with the Solaris, I’ve gone to small Symbios to get the deep insertion.
    subguy812 and cr3ativ3 like this.
  6. cr3ativ3
    Try Cowon plenue L . The qp2r do hiss with Solaris on balance out . And to my ears the PL sounds better , and don’t forget the chameleon like jet effect
  7. cr3ativ3
    Yeah spiral dots ( wide bore / same as nozzle size ) sounds best
  8. Wildcatsare1
    Could you please post a link.
  9. fzman Contributor
    I'm pretty sure it's a 361 not a 3461. Gonna be hard for him to look it up when you specify the wrong model number
    Wildcatsare1 and fokta like this.
  10. subguy812
    https://penonaudio.com/qls-qa361.html
    Thanks for correcting my error, it is so difficult to be imperfect with so much perfection around...he is correct it is QA-361
  11. subguy812
    I will try some more budget friendly DAPs this weekend. I wish I had a 2.5mm MMCX cable so I could get the most out of the DX120, because I have a feeling it would have a great synergy with the Solaris in balanced output.
    fokta likes this.
  12. cr3ativ3
    Yeah sounds good , I have both too.
    It’s my on the go dap :) but also slightly hissing on bal out
  13. cr3ativ3
    Get an balance cable .. it’s a much better output with the 120 , If you don’t want to break your wallet , look at FiioLC2.5c as example
  14. fokta
    what u mean is fiioLC2.5D right?
    wow, by spec, power is almost double then my current gear... Somehow I felt this DAP is intended for Headphone.
    My surroundings is make a noise about DTR1...
    both DAP mention above is quite rare in my country... even haven't try N6ii or N8 myself, although I predicted Warm sig, I will not like it, but still curious... hehehe
  15. cr3ativ3
    The D is better then the C but the C is cheaper , he mentioned he want to try something Budget friendly :D
    fokta likes this.
