Campfire - Solaris
359 360 361 362 363 364 365 366 367 368
370 371 372 373 374 375 376 377 378 379
  1. fokta
    morning... Have great day guys...
    cr3ativ3 and Wildcatsare1 like this.
  2. cr3ativ3
    Try spiral dots , same diameter , good seal
    I think you’re right with your statement , sounds better with them as with stock or symbio
    And good Morning :)
    ExpatinJapan and fokta like this.
  3. cr3ativ3
    evanescence synthesis live - > cowon plenue L -> fiio lc4.4D -> Solaris -> goosebumps :)
  4. medi1988
    Happy Solaris owner from Berlin here. I can absolutely recommend Spiral Dot Tips, with the bigger bore they give solaris some air to breathe with still fantastic bass compared with provided Final E Tips. Also the soundstage sounds more real and coherent i.m.o.
    Again head-fi had been very helpful with tips about these incredible in-ears.
    fokta, Wildcatsare1 and ExpatinJapan like this.
  5. cr3ativ3
    :ksc75smile::L3000::thumbsup:
  6. MaxD
    Anyone know where I can get Spiral Dot Tips in the UK ? I thought I had some but cant find them. Love to try them out on the Solaris :)
    Another Happy Solaris Owner :)
  7. cr3ativ3
  8. NovaFlyer
    No hiss with the A&K SP1000M. FYI, I also have the FiiO Q5, there's hiss with that, using iPhone as a source and 24/192 files.
  9. NovaFlyer
  10. medi1988
    I got them from eBay as well, about 1,5 weeks shipping to Berlin from Japan.
  11. MaxD
    eBay thanks for the tip.
  12. quodjo105
    Medium size symbios and final E fits me perfectly, should i get the same size for spiral dots or should i get MS or ML..first time buying spiral dots , so i'm a bit confused .
  13. zombywoof
    You may have to do a measurement to select the proper size Spiral Dots if you want to go with something comparable in size to the Symbios and Fianl E. My outside diameter measurements on the Spiral Dots are as follows:
    MS = 11 mm
    M = 12 mm
    ML = 13 mm
    L = 14 mm
    I never had the S size, but a good guess would be that they are 10 mm. Hope this helps.
  14. quodjo105
    thanks
  15. zombywoof
    No problem...I had same issue when I tried the Spiral Dots for the first time...
