I hear a crinkle every now and again...not every time, but enough that I notice it. I've decided to place my faith in the numerous manufacturers who insist that it's normal and won't damage the driver in the long term.
Campfire - Solaris
- Thread starter KB
Malevolint
I will admit that I found the methodology of that site to be strange. If you're gonna give out awards, you should put in a bit more effort than that.
I also don't have the Solaris anymore, but the best isolation you'll get is probably from foam tips. They also correct that bit of nasally tone that the Solaris has in the mid-range for me.
These are my favorite foam tips because they are of a gummy consistency and isolate very well:
https://www.amazon.com/gp/aw/d/B0722LZ66S
I haven't had the ety's for over a year now so I can't compare, but the Solaris sounds much more dynamic with better bass and also a waaaay bigger soundstage. The ety's were a bit more organic sounding, but nowhere near as fun.I was able to compare the Solaris to Andromedas, and also Tia Fourte, I liked the Solaris more than both, both sound-wise and fit-wise. In fairness though I spent a lot more time figuring out how to make the Solaris fit perfectly.
Interesting comments, thanks. So on this topic... which eartips offer the absolute best isolation with the Solaris? If its custom-made ones, then what are the best for isolation after that? Is there any consensus on this?
Also...as compared to the Etymotic, how are you (or anyone) able to live with the lesser isolation of an earphone like the Solaris? When I demoed them at e-earphone, I compensated for the room noise by turning up the volume. Is that it, basically? Because the extra noise can definitely be distracting otherwise, after all it's random noise interfering with the music.
As you've used both the Solaris and the ER4XR, I'm curious about how you'd compare the sound and anything else about them.
As another general question for everyone, I'm curious about where you most often use the Solaris, or similar high end IEMs that don't isolate very well. Is this an earphone that many use at home, or at home do audiophiles generally opt for speakers or larger over the ear headphones?
Yeah me 2I hear a crinkle every now and again...not every time, but enough that I notice it. I've decided to place my faith in the numerous manufacturers who insist that it's normal and won't damage the driver in the long term.
I found said review itself to in turn be elucidating. It was a tough decision between the Solaris, UE Reference presumably not remastered and certainly not 18+ pro which just sounds dirty, a $400 Audeze iem, and a $1500 iem I hadn't heard of that hasn't retained its value well when I was looking which top tier iem to get. At the end I gave the Solaris the best iem of the present award, and invoked the International Consortium of Boldly Subjective Sound Science to make it sound even more impressive.
I say good day.
I say good day.
elChefe
I notice a popping sound sometime when I’m putting them in but only when using silicone tips. I actually thought it was the tips making the sound since I don’t hear it with foam.Does anyone get driver pop routinely when inserting these? I experience this only when inserting due to my tight ears. I dont think this is an issue with the design or anything, but I'm wondering if this could harm the drivers over time.
I have another DD-BA hybrid (Fiio FH5), and those never click, even on deep insert, but the venting on the DD might be different.
candlejack
I also heard something similar (only in the L ear). I think the silicon provides a stronger seal and thus allows for larger variations in canal pressure which pull harder on the the driver diaphragms. This is not purely a DD thing either. I had a pretty nasty clicking noise in my Andromeda S which CA fixed and it sounded similar to what I heard on the Solaris (although it was much less frequent or annoying on the Solaris).I notice a popping sound sometime when I’m putting them in but only when using silicone tips. I actually thought it was the tips making the sound since I don’t hear it with foam.
Best BA bass I’ve heard is the fearless audio acme8 with its maze tube design .
mark88888
- Jul 23, 2010
Thank you, fantastic, if I get the Solaris (which seems likely) I'll definitely pick up those tips!
By the way, being that it seems we have similar taste in sound, I have to ask... why did you decide to sell the Solaris (how do you rank them?), do you have another recommendation? Also, did you feel that foam tips completely corrected the nasally tone you perceived? I didn't hear that but then again I have a lot less experience with them. I'm also curious about how you'd define "organic" and "fun", sound-wise.
Malevolint
No problem! My issue with them was that nasally quality. It was there, if slightly, and I'm a picky MF so it wouldn't stop bothering me. On the night before I sent them off to their new owner I tried the foam tips that came with my new U12T. It no longer bothered me! I was excited about the u12t and still sent of the Solaris though. Took me a couple days to realize how bright the U12T was and sold that off after a couple weeks too.Thank you, fantastic, if I get the Solaris (which seems likely) I'll definitely pick up those tips!
My other issues with the Solaris were fit (but you probably already know if that will be an issue for you), moisture accumulation on the end of the nozzle, and hiss with just about every source.I tried. It was minimal on my zx300 but still not something I want to deal with at $1.5k.
Sound wise, I would rank them pretty high. They have a pleasing, exciting sound and good technicalities.
I ended up with the QDC Anole VX and an Audeze LCDi4. They complement each other beautifully and I couldn't be happier after my long search. The Anole has none of the issues that I've had with previous IEMs, including the u12t and Solaris and it gets tons of ear time! It's an incredibly competent all arounder. The LCDi4 is a very special piece of gear that performs at the TOTL full sized headphone range but has no isolation. They're still more portable and easy to drive than most high end headphones, though, so I bring them out with me a lot.
Organic, to me, means true to life.. as in: if someone is standing in front of you singing, how close do the headphones sound to that? People don't have "sparkle" in their voice when they sing, or rumble for that matter.
I've also found overly organic to also sound boring, though, so I try to find some kind of balance between organic and fun.
Sorry for the essay lol.
<snip>People don't have "sparkle" in their voice when they sing, or rumble for that matter.
"Luke, you are my end-game iem"! (said in the voice of you -know-who
Interesting. I, too, have a Note 8, but I've never once used the headphone out for listening to music. Might just give it a try, since your impressions slant toward the positive side of things.Well, I can said, I am envy and also happy to you guys who can enjoy with the current gear.
Solaris pair with Samsung Note 8 is consider neglectable Hiss, and still until now, delivery quality Bass, Amazing low Value IO, Fast GUI, easy implementation & application for Streaming apps, and the most realiable for USB output in stacking (NX4DSD, Mojo, Alo Dual Mono etc)
what is lack compare to DX220, IMHO, and based what I experienced :
- Soundstage, Wider with (or because of) layer High freq
- Hi Mid Layered, I can said Note 8 can make this sound, but less refine and resolution.
- Sub Bass, more detail and resolution, where Note 8 can still win in Quality of the punch...
- Dynamic, is it obvious? cause less power... (Low volume application plz)
- Separation, this is more on the affect of Solaris itself since its alrd good, DX220 can emphasize that.
I was said that Solaris is source dependable from DAP and also Song file. And still...
Opinion about IEM effect the biggest chunk the SQ and Sound Sig is valid point and I agree...
But it also need a DAP to make delivery that...
Its take Two to Tango...
just my 5 cent...
great discussion here...
azeral
- Jul 27, 2012
I'm now the point with the Solaris that I've actually started to prefer them, fit-wise, over the other IEMs I own with associated shallow insertion.
Attached is the the depth they sit WRT my outer ear. This depth for me maintains a perfect seal, even during a light jog, even if it feels *very* deep. Curious if this is the norm.
I feel like these just need some time for those of us with smaller ears, and I'm not sure if my canals have adjusted after about 30 hours of wear, or if I just have oddly small ear geometry for 2 meter tall individual. It may be a little bit insane but I did start sleeping with earplugs in attempts to help these adjustments
And the sound? Now that comfort is where it needs to be, I can start focusing on this, but I can't recall enjoying the Andromeda this much. For me, the bass integration keeps me from seeking only low OI sources, while sacrificing little anywhere else (perhaps a smooth mids presentation). Over the moon at the moment.
More to come.
*edit: I've learned that my ear canal is lined with bone, so my perceived comfort increase is actually a mystery to me; no way my brain "wired out" the discomfort in 30 hours*
More to come.
candlejack
Fit looks pretty good to me. If that's comfortable, sounds like you have a winner.I'm now the point with the Solaris that I've actually started to prefer them, fit-wise, over the other IEMs I own with associated shallow insertion.
Attached is the the depth they sit WRT to my outer ear. This depth for me maintains a perfect seal, even during a light jog, even if it feels *very* deep. Curious if this is the norm.
Please do try, Its a good back up.Interesting. I, too, have a Note 8, but I've never once used the headphone out for listening to music. Might just give it a try, since your impressions slant toward the positive side of things.
and for me, Note 8 is very handy to search new song, since I used this for my daily smartphone.
I find the Note 8 is the best Stack combo for song source player, just plug it wirely to any DAC...
Wireless, hmm not that great, but will serve just find. the LDAC etc is quite buggy in soundwise...
Pairing with Solaris, U might be surprised that it can delivery good decent bass...
btw, make sure ur Note 8 is the Enyxos version, since the DAC used from Cirrus...
I know this has been talked about ad nauseum but I have gone through every type of eartip I have, including customs, and the Spiral Dots give me the best seal and sound quality, so far with the Solaris.
Total: 7 (members: 0, guests: 7)
