With the Andromeda I can see how impedance changes would lead to sound changes, but I wouldn't consider that a property of the cable, but rather the extreme impedance sensitivity of the Andromeda. I thought that the Solaris is much more stable though.
Oh yeah, in these situations I'm also measurement-grade sensitive. :-d
Solaris is sensitive also in fact I think the dynamic driver is rated at 3 ohm (don’t remember who posted this...) so the “global” impedance is not the only factor.
Cable apparently do have an impedance rating, I am not savvy enough to explain but higher wire count usually means lower cable impedance and it affects the sound.
This is just conjecture, so please don't take this as gospel (or informed technical debate!), but as the "mid" BA is firing full range with no bass/mids crossover in play, I suspect impedance change in the cable will be affecting the lower end of the BA contribution, irrespective of how the DD reacts. May explain why the low end can respond differently to diverg different OI / cables despite the DD sitting in there.
