sleepdeprecation
Campfire stock cables are surprisingly disappointing for a company that started by making cablesHated the cable with the awkward memory wire
The Smoky Lite Litz cable on the Honeydew is really comfortable and performed well for me.Campfire stock cables are surprisingly disappointing for a company that started by making cables
It's very easy to remove the memory wire. I've done it to all my CA cables and posted the instructions on HeadFi a couple of years ago.My listening session with the Sony WM1A single-ended has been flawless so far. No siblance in the treble yet comes off quite airy. Sub bass hits nicely with articulation. Mids have come forward with no sense of bloat but the right amount of bloom for my senses. The sound has come together as one for a pleasing experience.
This signature reminds me of my Atlas with heavy EQ but more balanced. The soundstage wraps around my head with good height reaching above my forehead.
Hated the cable with the awkward memory wire. Moved on to the EA Grandioso Special(Con-X). Much more comfortable.
Wait, CA has gone pack to using memory wire on these? Hope that's just because the copper cables are old stock or something because the newer Smoky Litz cables don't have any from what I can tell.
Hold the IEM end of the cable in your hand and let the rest hand down. Then take a hair on high and slowly use it on the full length of the cable. It should straighten it out.my problem with the campfire cables is just that they hold memory, i unwind them from being coiled and there’s just a million kinks that never go away
@01BXTR Thanks for sharing initial impressions. Are you an Andromeda owner? I'd be curious as to how they compare.
I was an owner of 2020 Andros about a year ago. They were far less treble extended to my memory, and more bass heavy. Andro 2020 are closer to what I'd want in a Harmon target for over-ear headphones, neutral ish with a bit of a base shelf. These are definitely more like Grados, high energy and treble extended.
How's the bass?
How's the bass?
Present, controlled, bit of a roll off in the sub-base, not that different then how Senn HD 6 series bass is.
