Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
537 538 539 540 541 542 543 544 545 546
548 549 550 551 552 553 554 555 556 557
  1. rantng
    We all hear differently and everyone has their own preferences, but both of you present very valid points and I found both posts very helpful. It does show that there is no substitute for hearing with your own ears.
    Colors and ExpatinJapan like this.
  2. Colors
    On another positive note, AG + Symbio W are isolation monsters. I can pretty much listen at the same volume on the subway and bus which is crazy. Must be the longer noozles + increased bass.
  3. cr3ativ3
    i check out these combo later... currently im using spiral dots
  4. cr3ativ3
    to my ears , the "overall" sound is very similar with symbio w and spiral dots , but the stage seems a little bit bigger with the dots .. i prefer them :)
    Colors likes this.
  5. Colors
    For me, I get a better deal with Symbio W. Haven’t tried Spiral Dots yet but I can imagine how the wider nozzle would allows more treble = better stage. I just could never get a tight seal with it.
  6. cr3ativ3
    Seal is everything :)
    gc335 and jmpsmash like this.
  7. Giraku
    I happened to get an additional Andromeda Gold. Does anyone want to buy? The package has been opened, and the IEMs are tested for one hour.
  8. ilovetoys
    So I got the 789 anyhow and after listening to it for almost a week, the only thing I notice between it and the Atom is the 789 has less bass. Kind of makes mids and highs seem more pronounced. Really like it when listening to orchestral music and classic/folk rock. The convenience of not using an adapter and having more volume knob to work with may of been worth the price alone to me. Plus it's so pretty...
    Colors likes this.
  9. iMongui
    Today I did a Frankenstein but oh god, I found the perfect combination !! I putted the foam of a Symbio W inside of a couple of Spiral Dot and I found the best combination possible !! The Symbios are very hard in terms of material and I start to develop a pain after few minutes of start using them, but Spiral are the most comfortable of all tips for the Andro but they don’t isolate correctly. With the foam, the isolation it’s the best by far and the sound it’s improved a lot, the perfect for me !!
  10. rodel808
    Grab a pack of foam ear plugs. Cut out a hole with what ever tools you have. I used a leather hole puncher but I've also used a sharpened refillable pen successfully... Just takes more time to get a clean cut. Then stuff the foam into whatever silicone tip you have and snip off the excess length of the foam. Violà!
    candlejack and Cann3dh33t like this.
  11. PixelSquish
    Excellent. I'd make one with red foam and one with blue foam so I always knew which IEM was right and left much quicker than having to pick them up first.
  12. thrgk
    Are Andromeda larger than IT04s?
  13. cr3ativ3
    I don’t have the it04 but from pictures .. I would say the andros are smaller
  14. thrgk
    Ah cool. My ears are small , I like how the clamshell nuforce fit but looking for better quality.
  15. cr3ativ3
    9F104643-2B5E-4E85-8D3A-7F9034585FCC.jpeg F3EEE613-83A2-4141-8E08-E6EFDBC64145.jpeg
    Here next to Solaris , the andro isn’t really that big .
    Aslshark likes this.
