Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
403 404 405 406 407 408 409 410 411 412
414 415 416 417 418 419 420 421 422 423
  1. Dsnuts Contributor
    Ya. I always thought the foams was glued into them symbios but they are just inserts. I think the silicones themselves is way more comfier. Another cool thing. You can insert them foams into other tips like the Spiral Dots and make them more isolating.
  2. autosleeper
    Gonna try that right now! What a day of discovery this has been :)
    Think I'll spend the remaining 6 hours at work listening to the new Beatles White Album super deluxe set with these modded tips.
    Aslshark likes this.
  3. Fatsosixsixsix
    I tried removing the foam from my Symbio but it seems the top of it is glued on mine
  4. Dsnuts Contributor
    Hmm shouldnt be. Try flipping the entire upper shell bakwards.
  5. Fatsosixsixsix
    That's what I was trying to do but there was a weird glue-like substance between the orange foam and the rubber earbud itself right at the top. The sides weren't glued on though
  6. Dsnuts Contributor
    Strange. I got 6 pairs of large W and all of the foams came out with ease.
  7. Caruryn
    Big thumbs up for me too for Symbio W minus the foam.You hear more textures,the sound is more nimble and less thick but you also lose that mid bass sluginess that some complained especially with the stock campfire foams.
    ExpatinJapan likes this.
  8. viper2377
    They have in the past, I would like confirmation for a Black Friday deal for 2018 also. Any one care to shed some light on this?
  9. Fatsosixsixsix
    Campfire Audio does Black Friday deals but I believe it's mainly on their cables and B-stock. I seem to recall that new Andromedas were explicitly excluded from the sale
    viper2377 likes this.
  10. ExpatinJapan
    thanks for this.
    As you know I tried it with the CA Solaris and it is proving popular on that thread (I forgot where I saw it so I didnt quite you, sorry).
    I suspect the same might be said for for the Atlas also (stillto try). I havent tried it with the Andromeda yet - usually using JVC spiral tips.
    I have found the Symbios useful for say the Dorado, the tip design being for outer ear and not inner.
    Your suggestion to remove the foam works well.
    The Symbio W bore is a nice medium and not so large as the Spiral tips and not as narrow as final/spinfits. Plus the Thick silicone works as well as the Spiral tips to retain the lows and mids.
    Easy mod for maximum satisfaction.
    Dsnuts likes this.
  11. ustinj
    [​IMG]
    A wallpaper for those who still enjoy their Andromeda, especially with all the new products coming out.
  12. viper2377
    Ahh gotcha! Thanks for your insight, may just go new then.... just a bit concerned with the comfort/moisture issues some have with them.
  13. Fatsosixsixsix
    The current version has slightly more angled edges to reduce the number of sharp edges I believe, although I had no comfort issues with mine at all
  14. viper2377
    Much appreciate your input, think I’m pretty close to talking myself into taking the plunge
  15. ustinj
    [​IMG]
    Quick Comparison between Original Andromeda & Andromeda S
    Now for some actual contribution... I managed to get a hold of an Andromeda S from a friend to compare with my original Andromeda. I did a bit of reading prior through this thread and found very mixed opinions on which tuning they preferred. Curious to get to the bottom of the dilemma, I did about a day's listening and drew some conclusions.
    I found the original Andromeda more comfortable, the stainless version is noticeably heavier and puts more pressure on my outer ear.
    My verdict is that neither the original Andromeda nor the Andromeda S is 'superior' to the other. It is, as usual, preference. Differences are SLIGHT -- if you didn't like OG Andromeda, you probably won't like Andromeda S.
    The Andromeda S has a slightly more forward midrange, mainly in the midsection of vocals. I find it results in a more immediately apparent texturing, but also tends to sound a tad bit more intimate in presentation. The original Andromeda has a more laid-back upper midrange. Vocals aren't as upfront, they sound further away in the mix. However on a good note, the original Andromeda's presentation is noticeably more spacious and 'large' sounding (this is part of the magic that Andromeda became famous for).
    In terms of treble, it seems like a very close call. The original Andromeda's treble sounds a bit more delicate and fleeting, with a beautiful sparkly presentation. The Andromeda S, in my opinion, does retain the signature sparkle Andromeda is known for -- however, I find that due to the more forward midrange and slightly more intimate staging, it loses a touch of its smooth, shimmering 'silkiness'.
    I say it's all relative: there's no actual change to the treble directly, but the modification to the neighboring upper midrange shifts my perception of the treble. There's no way I can afford to keep both of them (nor would I want to, since they're so close to each other), though I am torn between the slight sonic nuances between the two. It comes down to whether you prioritize vocal texturing (Andromeda S), or a slightly more spacious staging with magical treble (original Andromeda).
    bennybennyta, Aslshark, fokta and 9 others like this.
