Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
post-13528744
Post #4,051 of 8,928
vilhelm44
I see you're using the Symbio eartips, I'm so glad I found those as they've been the best match for me with the Andro. Been really impressed running them SE from the WM1A, am thinking of getting a balanced ALO cable next. Do they improve a lot from WM1A balanced?
post-13528950
Post #4,052 of 8,928
blazinblazin
Haha that's very cute! Probably too large to put them inside the Campfire Audio case though, but perhaps it's worthwhile looking into a dedicated IEM case/bag like other users have
Most of the time i will just left it plugged into the player. Then use the cute pouch to protect the iem and just put into bag without any case.
Too lazy to take them out of pouch and case then put them back as i use them daily.
post-13528954
Post #4,053 of 8,928
blazinblazin
Yes i like them a lot as they dont give me the "tunnel" sound like some other tips.
These are Symbio W tips.
Normal Symbio tips i felt gave a more concentrated/focus sound actually more bass. W gives you a more spreaded sound which i am still testing if i like these or old ones more.
Actually 4.4mm balanced itself is already an upgrade in sound without factoring in the cable.
post-13529255
Post #4,054 of 8,928
vilhelm44
Thanks, I'll pick up a balanced ALO cable. Yeah, I'm using the W tips as well and find they give a good balance and great seal. I haven't tried the normal tips as yet so may give them a go.
post-13534760
Post #4,055 of 8,928
csps12345
Limited Edition Andromeda(Polished Brass)& Limited Edition Andromeda(Polished Aluminum-Silver Screw)
China only:cry:
post-13534814
Post #4,056 of 8,928
KEV G
LONDON
LONDON
China only:cry:
Think I prefer the green, just something about that colour works really well(for me anyway)
post-13534818
Post #4,057 of 8,928
Fatsosixsixsix
China only:cry:
The brass just seems overly gaudy to me. The silver is pretty nice, but like Kev G I prefer the green to be honest
Reactions: KEV G
post-13543725
Post #4,059 of 8,928
esm87
Bit of a strange situation. I have been loaned a pair of Andromeda. They work with my samasung galaxy s6 edge + but for some reason I cant get them to work with my galaxy s8??
Anybody able to help??
Cheers
post-13544197
Post #4,060 of 8,928
Asspirin
Southern Germany
Southern Germany
Cheers
Do other earphones work with the 8? Could be a faulty 3.5mm jack
post-13544261
Post #4,061 of 8,928
esm87
Ye lol. I use various IEM's and HP's with my s8. At first I thought my 3.5 jack was goners but no, all my other gear works?
It's as though there's a compatability issue?? Why there would be one though I have no idea it's onely a HP jack...
Thanks for input though
post-13544294
Post #4,062 of 8,928
blazinblazin
1/2 plug the jack in till you feel resistance of the jack, hold it there. Listen for a click sound from the earpiece. After that fully push it in.
Somehow S8 dont works well with some 3.5mm jacks. Very funny.
I had a S8+ having this detection problem.
post-13544312
Post #4,063 of 8,928
esm87
So push until no longer loose, will the click come through the earphones or a physical sound?
Once click detected, push in fully?
Bizarre.... well on my way to work now so will have to try it when I get home later. Thanks for this! From short listening impressions, the BASS on these is wicked! A few drake tracks punch holes in your ears, will compare the sound to my other IEM's.
Cool looking too. They are a bit scuffed from general use but I imagine new, these must look the s**t.
post-13544324
Post #4,064 of 8,928
blazinblazin
Its a electronic click coming from the iem.
Its like the phone have detected your 3.5mm jack n sending power through it.
post-13544327
Post #4,065 of 8,928
esm87
@blazinblazin cheers bro. How do they sound paired with s8? I put trinity kombi tips on them, seem to be a good match, good seal, full solid low end.
The difference from s6 directly to the mojo with these was big, mojo adds weight to the whole spectrum, as though everything comes in fuller with a spacious sound to my ears, from brief impressions
Users Who Are Viewing This Thread (Users: 2, Guests: 4)
