faultfracture
- Apr 13, 2016
After reading Tyll's article on output impedance and how it "EQ's" the headphone to its impedance curve I wanted to figure out a way to mathmatically predict the results on different sets of headphones. I made this spreadsheet with the voltage divider networks discussed by Tyll and added some basic loudness calcs (with constant sensitivity) to try to predict this. These are based on the HD800 that Tyll measured...
So the PX100 suffers more of a boost to the point of its impedance peak with only a 20 ohm output impedance than that of the HD800 with a 200 ohm output impedance. How should I correlate these values to figure the boost I could expect over a 1-ohm output impedance with any variable amp output impedance and a headphone's impedance characteristics?
HD800 (102 DB/V) | ||||||
Freq | Vamp | Zamp | Zhp | Vhp | db (102db/v) | Diff |
1000 | 1 | 1 | 361 | 0.997238 | 101.9664 | |
100 | 1 | 1 | 635 | 0.998428 | 101.9809 | 0.014503 |
1000 | 1 | 100 | 361 | 0.78308 | 99.02658 | |
100 | 1 | 100 | 635 | 0.863946 | 100.2216 | 1.195043 |
1000 | 1 | 200 | 361 | 0.643494 | 96.63924 | |
100 | 1 | 200 | 635 | 0.760479 | 98.67044 | 2.031201 |
PX100-Iii (115 DB/V) | ||||||
Freq | Vamp | Zamp | Zhp | Vhp | db | |
1000 | 0.25 | 1 | 37 | 0.243421 | 97.81803 | |
100 | 0.25 | 1 | 82 | 0.246988 | 97.99492 | 0.176894 |
1000 | 0.25 | 10 | 37 | 0.196809 | 95.23323 | |
100 | 0.25 | 10 | 82 | 0.222826 | 96.74305 | 1.50982 |
1000 | 0.25 | 20 | 37 | 0.162281 | 92.88747 | |
100 | 0.25 | 20 | 82 | 0.20098 | 95.4883 | 2.600831 |
