shirleywhite
- Feb 10, 2005
Hi all.
Got my Caffeine Ultra just before Xmas but only just starting using it. Got a problem though - and would appreciate forum advice before I get back to Robert in Germany.
Basically it plays fine if used off mains power- a 12v source plugged in directly. But if I use batteries the sound cuts out if I turn the volume knob up beyond about 9/10/11 o'clock(where 6 oclock is "zero"). I've tried it with bass boost on and off - also high/lo gain- and into full cans or iems. Makes no difference. Sound cuts out at some sort of "mid" volume point!! If I unplug the phones and plug straight back in -it comes back but then usually cuts out again after a second or so. It's almost like having an automatic volume limiter kicking in when using batteries!
I tried both alkalines as well as 9.6v maha/powerex rechargeables -- same result. Anybody else had this?? I'm 99% sure it's a faulty amp and will be returning for a replacement hopefully. But thought I'd check in with forum experts first!! Thanks.
