Chuck Dee
Member of the Trade: Chris Cables
- Jan 6, 2013
The first and most obvious difference between internal and external wiring is the 'environmental conditions'.
The internal wiring will have been designed, developed and tested to work properly in supplying an optimal signal between the connector(s) and drivers. This will include consideration for EMI/RFI interference, distortion, resonance, capacitance, impedance and any potentially detrimental effects on the signal path.
Not all headphone manufacturers place the same importance or consideration on the internal wiring however so there will be variance for quality and implementation but most will have at least given minimal consideration during the design/development phase and I consider that this has only improved in general over the last 30 years.
My favourite 'Made in Ireland' era of Sennheiser headphones are testament to the fact that things were done, let's say, sub-optimally in the past, what with those micron-thin conductor wires running through a hollow channel in the driver/cell structure from the connectors to the voicecoils. I think the design has carried through to the current 660 drivers if I'm not mistaken. When those wires break accidentally or otherwise there's NO repairing them. Go near them with a soldering iron and they just evaporate! I recall Tyl Hertsens trying and failing to repair one of these wires and it's also documented here.
External cables DO make a difference whether you believe they do or not and I'm also not really interested in getting into a debate about it. All I'll say though is that new signal-characteristics such as 'timing' and 'propagation' are being discovered, measured, analysed and demonstrated to make audible differences.
Alpha Audio here in NL recently conducted some interesting analysis on various cables here.
Far from conclusive but interesting nonetheless and certainly warrants further investigation in my view.
Microphonics-damping and EMI/RFI-mitigation should be minimum characteristics of all headphone cables and I'm constantly amazed at the poor quality proprietary cables supplied with some TOTL headphones! Looking at you Meze and Hifiman!
