C-media USB Sound Card
Nov 29, 2018 at 4:53 PM Thread Starter Post #1 of 4
markito331
argentina
Hey everyone, thanks in regard.
I have a pair of recentrly bought Sennheiser 598 SR, and i listen to mostly classical music through Tidal.
I bought a budget generic USB Sound Card, with CM6206 chipset. (https://www.nisuta.com/producto.asp?id=NSCOUSAU7)
I was looking to invest some money into a proper amp/dac, and the only ones available in my country are the fiio e10k, Q 1 Mark II, or Q5.
I listen to music in my desktop mostly pc.
The problem i have is that classical music is often recorded at low level volume.
Do you think it is worth the money?
thx.
Nov 29, 2018 at 6:51 PM Post #2 of 4
I have a pair of recently bought Sennheiser 598 SR, and i listen to mostly classical music through Tidal.
I bought a budget generic USB Sound Card, with CM6206 chip-set. (https://www.nisuta.com/producto.asp?id=NSCOUSAU7)
Do you think it is worth the money? thx.
I would go for the FiiO Q1 MKII
Nov 29, 2018 at 8:41 PM Post #4 of 4
thx for your reply, why? it is more expensive though.
The Q1 is a much newer model, then the E10K and I believe the Q1 has a better DAC chip.
