Adelfaidah
Hey guys i have a very specific problem. Basically, I own the hd650 and JDS lab the element AMP/DAC. So at first I started noticing a buzzing noise in the right ear cup when the bass goes low and loud, after hours of trying to figure out the problem I found out by opening the grills and pressing on the small foam it would disappear, so i stuck a small piece of tissue on top of the small piece of foam (problem solved) however i noticed another problem which happens with the tissue or without it and that is, while there is a low bass playing if i decide to change the volume either higher or lower I'd start hearing a fast flapping sound like a paper fan on the right ear cup, but once i stabilize the volume it doesn't seem to appear also if i change the volume digitally through the laptop it does not occur, it only occurs if I'm analog-ally changing the volume I.E I'm turning the volume dial on the jds the element AMP/DAC.
Anyone have any suggestions as to why this is happening? i know its not a major issue as once the volume is stable its basically perfect but I'm still kind of worried as this doesn't seem normal. I did think of removing the small foam and see if it would solve the problem but I'm afraid i wouldn't be able to reverse it. the small tissue
