Buying M-stage amp
Jan 9, 2011 at 7:09 AM Thread Starter Post #1 of 11
Jonasklam
Hi mates,
I'm looking for a M-stage amp and came across this website: http://www.audiophilechina.com/cp-show.asp?C_id=216&S_id2=2&s_id=91
Have anyone ever heard about or purchased from them before? It seams a little suspicious to me.
Also, as I can understand, there are many different versions of the M-stage. Anybody who knows what the differences are? I donnot have time for searching throu' the long "M-stage Matrix Thread" for the answer :p
Jan 10, 2011 at 11:18 PM Post #6 of 11
 I bought mine from them, it saved me some $$$.
 For a better sound you should try other opamps, for this you have no other option than read that thread.
Feb 3, 2011 at 4:59 PM Post #10 of 11
I did not.
I ordered from http://coolfungadget.com/store/index.php?route=common/home just yester day, so i donno if everything is ok. Sure hope it goes smooth :p
If it helps I just received my M-stage from coolfungadget and everything went very smoothly.  It took about 13 days from the order date to receive the amp here in Western Canada.
Feb 3, 2011 at 6:12 PM Post #11 of 11
Cool man, it does :). I was getting a little suspicious :p
I did not.
