Hello,
This post was firstly published in the O2 thread, because I was not aware of existence of Burson's thread, so I'm gonna just copy-pasted here, in case anyone's interested to read about it. Thanks!
I did myself a complete test with the new solid-state BURSON V5-D op-amps in my Objective2 headphone amplifier. Everyone knows that O2 sounds very good "by default": it has a dark background, sounds quite neutral and doesn't emphasis treble nor bass, so I didn't expected much improvement over original sound, though I was hoping to get a little bit of a bigger sound-stage.
Headphones used for this test were Dr. Beats Solo 2 (32 ohms), AKG K701 (62 ohms), Beyerdynamic DT880 (600 ohms) and DAC used was ASUS Essence One MKii MUSES.
Music used for this test was FLAC:
- Chesky Records - The Ultimate Demonstration Disk
- Ultimate Demo Disk
- Super Audio Check
- Legendary Sound (LS3/5A)
- The Nordic Sound - 2L Audiophile Reference Recordings
- Ayre - Katie Mahan Collection
- Head-Fi And HDtracks - Open Your Ears (2010)
What am I comparing these BURSON op-amps with? Well, I already have MUSES8820 in my O2's VAS right now and I'm quite pleased because I found MUSES sound being a little bit more spacious and cleaner than the original NJM2608. As output buffers I have NJM4556A, original O2's paralleled buffers.
Test with SS V5-D in Voltage Amplification Stage (VAS):
- Sound is definitely more detailed with V5 then with MUSES8820, especially when cymbals are involved...hmmm, I didn't expected that. Details in cymbals were immediately noticed, without feeling any increase in trebles, so the same neutral sound but more detailed and with much better sound accuracy; now cymbals sound like I'm on the scene.
- Women voices are very clear and "mild" even when singing loud, not fatiguing at all. Also Kenny Roger's saxophone sounds better in every way, like a delicate immersion into the music. I am sensitive to saxophone and to women yelling, especially when DT880 are used, so BURSON V5 is really helping me here with their sound.
- Bass sounds about the same as MUSES to me, noting has changed I'd say. I tried "Chesky - Percussion Test" and also "Ultimate Demo Disk - Percussion" and I couldn't realize any differences; I got the same fast and powerful bass, especially with my K701 headphones.
Test with SS V5-D as output buffers:
- I was unable to get any noticeable differences between the original NJM4556A op-amps and BURSON V5-D, though scene might get increasing a little bit, but not much to make a difference.
- As O2's output buffers are directly connected to headphones, DC-output voltage of SS V5 op-amps might be a little bit higher for low impedance headphones (see V5's datasheet). For 60 ohms or higher impedance I don't see any concern here.
PROS:
- Upgrading Objective2's VAS op-amp with solid-state V5-D from BURSON will get you the same neutral, natural, clean and balanced sound, but with
more details in sound and with
increased sound-stage.
CONS:
- Price, especially comparing with O2's MSRP.
- Size, because you'll definitely need a taller case like B4-080 model or some DYI case made of acrylic or anything else (3D printer perhaps?).
Note 1: BURSON V5-D op-amps were both tested for any possible oscillations or strange harmonics by using Pico-Scope. Nothing strange was found, of course, feel free to check attached screenshot.
Note 2: V5's temperatures during this test were between 43-49C in free air/open case (24C room temperature), depending on the volume uses. IR thermometer was used to read the temps.
Note 3: Many thanks to BURSON for providing me those 2 dual solid-state op-amps to do this test!
