Following @Timbuk2's post earlier I have also contacted Burson regarding the new volume chip with updated programming. It is actually the exact same chip, only the programming makes the volume curve smoother. This means there are no jumps anymore, the 51-52 volume jump is gone. It is all smooth and balanced across the range.
Burson immediately answered my request and sent me two chips (just as in @Timbuk2's post). When I inserted the first chip the amp went totally silent. Luckily when I tried the second chip everything was back to normal and the 51-52 jump disappeared. (Apparently there are two versions of the same chip and it is impossible to tell which one will be compatible with your amp.)
It took Burson a week to allocate a sound chip for me from their factory and another week for the post to arrive from Hong-Kong to the UK.
I am pleased with the service and the result. If the slight 51-52 volume jump bugs you, I recommend to contact Burson as there is an easy fix.
