Burson Soloist 3X Performance Head/Pre Amp - 8Wpc XLR with MUSE72320 volume control
Mar 6, 2021 at 9:19 PM Post #721 of 1,749
KevP
Thanks for the education. After I wrote that I realized that it makes sense if you are playing files rather than using streaming services. In that case, they act as a network drive and make perfect sense. (Duh!) What throws me off is seeing every new streamer talk about Spotify, Tidal / MQA, etc. That part seems strange to me when you can use a phone as your audio source and get nearly lossless quality over Bluetooth.
Or connect a high quality DAP as I’ve done via the XLR inputs, streaming Tidal Masters over Wifi and accessing the 10,000 tracks I have stored on the player.
Mar 6, 2021 at 9:28 PM Post #722 of 1,749
normie610
Jakarta, Indonesia
I do this except I put a DAC in the middle. I did try the exact setup you mentioned, but there’s an improvement in sound (minimal but noticeable) when I have an external DAC.
Mar 6, 2021 at 9:32 PM Post #723 of 1,749
KevP
Hi
Just received my Burson soloist 3x, running rca from a hugo 2 and a pair of meze empyreans. Didn't expect to need to run in high gain to be honest ! My knowledge of amp power output and headphone requirements isn't the best but I would have expected low to medium gain would have been sufficient. My hugo 2 headphone out seems louder than the soloist. Am I misunderstanding something or do I have an issue to worry about ?
Just received my Soloist and was also really surprised that the gain and/or volume needed to be so high. So much do that I couldn’t hear anything at what I thought would be normal-ish volume at thought there was something wrong with it.
Mar 6, 2021 at 9:36 PM Post #724 of 1,749
MakubexGB
At what gain setting did you feel it was too quiet? Even at high?
Mar 6, 2021 at 10:06 PM Post #726 of 1,749
normie610
Jakarta, Indonesia
I was thinking, do I buy the Soloist 3XP or should I wait for the 3XR version? :)
Isn‘t the term “Reference” used to differentiate between single and dual DAC chips? If yes, then there should be no Reference version for Soloist :relaxed:
Mar 6, 2021 at 10:10 PM Post #728 of 1,749
normie610
Jakarta, Indonesia
Why call the Soloist 3XP then? Calling it Soloist 3X would be sufficient, being a balanced amp. The single ended version, if ever gets released, should be called Soloist 3, right?
At this point, only Burson knows the exact reason for the name convention :sunglasses:
Mar 7, 2021 at 12:42 AM Post #729 of 1,749
qsk78
Russia
Size wise both Soloist and Composer are similar to their Conductor single DAC Performance line as far as I understand. So It can be a reason they add "P" (Performance) to Soloist.
BTW, Composer is a single chip DAC. I think sooner or later they may come up with Composer 3XR on dual DAC, who knows...
Mar 7, 2021 at 2:52 AM Post #730 of 1,749
normie610
Jakarta, Indonesia
Agree. We’ll see later on.
Mar 7, 2021 at 3:19 AM Post #732 of 1,749
normie610
Jakarta, Indonesia
So, you’re not using the DAC in the DAP? Or have I misunderstood?
Correct, I’m using Burson Composer 3X as the DAC. The DAP only acts as the digital transport/streamer.
Mar 7, 2021 at 4:20 AM Post #733 of 1,749
KevP
That’s interesting. One of my DAPs is the Hiby R8. So you think the Composer makes a difference of sorts?
Since you’ve obviously tried the R8 directly into the Soloist, what volume on each did you find you needed to reach for reasonable listening levels? When I set it up for the first time yesterday, at first I thought there was something wrong as I couldn’t hear anything with the R8 on around 35 on high gain and the Soloist on around 50 on high gain, driving my Odins. I had to crank it up to 70 on each. But on medium or high gain on the Soloist I get a lot of hiss on the Odins. That disappears at low gain, but then I have to crank it up even more to the point where there is no head room.
Mar 7, 2021 at 4:28 AM Post #734 of 1,749
normie610
Jakarta, Indonesia
Yes the Composer definitely makes a difference. Bigger soundstage, better instrument separation.
When connecting R8 directly to Soloist, I was using the 4.4mm LO and crank the volume all the way up to 100. I just control the volume from the Soloist. I didn’t try my IEMs with this setup, but I did try them with Composer as DAC and R8 as transport. Erlky had a lot of hiss and Fusion has no audible hiss but the sound is not that good, even in low gain. I’m sticking to headphones for Soloist.
Mar 7, 2021 at 5:02 AM Post #735 of 1,749
KevP
Yes, it was better with the Stellias, but I would like the option to use iems sometimes.
