Burson Conductor 3 Performance & Conductor 3X Performance
Oct 25, 2021 at 4:17 PM Post #166 of 177
C-Bass
Seattle
You have to use the menu. 4-5 clicks. I switch often like that as I also use my Soloist as a pre. Takes about 10 seconds or less to switch. It would have been great to have this functionality on the remote. Instead the remote has functionality to switch input between XLR and RCA (as well as on/off, volume and mute). Edit: Sorry thought I was commenting on the Soloist thread. I'm not sure if the Conductor menu is the same.
It’s the same. One of the big misses by Burson. You can either use the headphones, have it output as a dac or have it output as a pre amp. It can’t do any of these things simultaneously and you have to use the clunky menu to switch. Should have absolutely been an option on the remote if possible.
Oct 26, 2021 at 8:40 PM Post #170 of 177
srinis
Australia
Hi everyone
I just received my new 3XP yesterday. Love the sound but I am having a lot of problems with the usb c cable. The one which came with it died in 2 seconds. I’ve on to my 3rd usb c cable but the music keeps stopping within minutes even though the source keeps indicating that its connected.
Any advice to fix it or is the unit faulty?
Regards
Oct 27, 2021 at 12:27 AM Post #171 of 177
walkmanforever
Hi everyone
Regards
Looks like a faulty unit to me. Try changing your source if that helps. Also, try the Toslink/Optical input to test if it's only the USB c input at fault or not.
Oct 28, 2021 at 12:15 AM Post #172 of 177
srinis
Australia
I later found out that 3 USB C cables did not work but USB A to C connected to my MacBook via a USB hub worked just fine. Does anyone have any suggestions as to what brand of USB might work as I am aware that not all USB C cables are not standardised.
Oct 28, 2021 at 12:33 AM Post #173 of 177
benneyb
New Jersey
Srinis, I had the same issue with USB C cables, and also as you did, had problems with the Burson provided USB C cable. I just picked up a Composer/Soloist stack that was sold by a member here (terrific, smooth transaction BTW).
It seems these units are quite picky about the cable. I have numerous ones, although no "audiophile" usb cables, and have had luck with a couple of USB C cables, and also with usb c to micro usb with an adapter.
Oct 28, 2021 at 5:12 AM Post #174 of 177
srinis
Australia
Thanks bennyb. Glad to know that I am not the only one. I’ll email them and see what have to say about this, which seems to be something to do with cable compatibility than a hardware issue
Nov 16, 2021 at 6:00 PM Post #175 of 177
SLimy
Wallachia
I have both the Conductor 3X Reference and the 3X Performance and I love them both; absolutely the best headphone amps I have owned (so far).
Hi,
I am also interested in buying c3x Performance or c3x Reference, but I have not found anywhere or anyone to say if it is worth the extra money for the Reference. Could you tell from your experience what is the sonic difference between them?( soundstage, separation, resolution etc) I just heard Reference is better. Is it worth it to go directly to Reference?
thx
Nov 17, 2021 at 2:16 AM Post #176 of 177
Terr0rSandmann
Germany
Hi,
thx
Reference has more hump and background noise with IEM 😉
But if you read through the www you will anyway find just posts which says that the more expensive units sound better (not really related the 2 mentioned Burson devices)
Nov 17, 2021 at 3:08 AM Post #177 of 177
SLimy
Wallachia
I am aware of more background noise from C3XR. I would like to know something quantifiable, even if it is purely subjective. Something like on soundstage R is 1-2% more than P, for example. Did you have the opportunity to listen to both amps?
