Building headphones with T1 drivers help
Sep 1, 2018 at 1:26 PM Thread Starter Post #1 of 1
karel88l
Hi,I am building headphones using Beyerdynamic T1 gen1 drivers.Custom headband with some Beyer spare parts used and ear cups machined from plastic.
Questions i want ask:
Should I buy original Beyerdynamic cable (57 Eur) ? or should I make own i will use Tasker 24 AWG wire probably (its ok ?)
Should be cable soldered directly to driver or can I use connectors (probably mini XLR) is here big difference ?
I have no idea how to connect wires i will use 6,3mm TRS(?) jack on end,if anybody can draw wiring diagram it would be very very helpful.Thanks.
Dont know if this image below is right.
