mrinspire
- Apr 30, 2012
Bughead sounded very liquify and organic, I really love it
Hear, hear! I just got introduced to this little wonder, and I'm perplexed of the plethora of options. But even without any tweaking, by using the default settings, this player sounds phenomenal. I know it's worth the time to dig deeper into the manual!
These settings seem to work best for me (could be a good starting point for you):
Under 'Select Option 1'
1, 2 and 3 should be RED. 6 and 7 should be RED (Setup DIMM should be 1: 2GB / 2: 2GB... this is with 8 GIGs of RAM which I have, if you have more, you can increase it) Be sure it tick "enable this mode" in the box.
Under Select mode 2
1 should be RED
Disable stardust mode - you can enable it if you want, it does make the sound more "sparkly" but I personally find it sounds too processed and not very natural.
When the main player screen starts, Over to the right and down a little, you will see a small box labeled 'mmx+', click it and scroll down to 'Tuning rewrite avx', select 'Tune amx plus'. Click the small box above that one... My favorite right now is 'Slash'.. Click it.
That should get you started on some really good sound, and you can tweak with the different settings if you want from there. Personally I feel there are way too many options, so I am sticking with this for a while.
Bughead doesnt let you load songs of differing resolutions in one session. It has to all be the same format per session/playlist
Hi Guys
If you are interested in a very active BH thread, check the Jplay forum:
http://jplay.eu/forum/index.php?/topic/1553-infinity-blade-hq-bug-head-emperor-worth-trying/page-164
164 pages / 3268 replies / 265K views
This player is amazing and keeps getting better. Oh yeah, it has it's quirks, but the SQ is so worth. No other player comes close.
Bughead for president! Best player I've ever encountered. I remember you from Jplay forum...what is your current settings for Bughead? Or you have been using Infinity Blade?
Nice to be remembered. I'm running Infinity Blade. The current BH program is 7.12 SP5. You can get it here:
http://oryaaaaa.world.coocan.jp/bughead/
I'm running 7.12 SP3 which I prefer. If you PM me, I can send it to you.
To get the most out of it you need at least an i5 quad core processor and 8 - 16 gb of ram(best is 16gb dual sided).
Hiroyuki continues to improve it. He is amazing....some kind of obsessed, eccentric genius/wizard. This player is his great obsession.
