Brise Audio
Sponsor: Brise Audio
Brise Audio launches "FUGAKU" Ultimate Portable Audio System.
FUGAKU is an system that brings together all the technology we have.
FUGAKU is available in September for 2,500,000JPY.
The purchase page and product page are as follows.
https://briseaudio.com/en/products/fugaku
https://briseaudio.com/en/pages/fugaku
Earphone
◆PVD black coated pure titanium housing
◆Ear hanger structure for improved wearing stability
◆8-driver 5-way configuration
Ultra high frequency : MEMS speaker x1
High frequency : BA driver x2
Midrange : BA driver x2
Mid-low range: BA driver x1
Low frequency : 2 x 8mm dynamic drivers
◆Wide frequency response over 100 kHz
◆Multi-amp connection with original 7-pin connector
◆Crossover circuitry integrated on the amplifier side
Dedicated portable amplifier
◆4-layer board (power supply) + 8-layer board (amplifier) 2-story structure
◆Electronic volume MUSES72323 is used
◆Active crossover for a total of 10 channels on the left and right sides
◆Power amplifier with a total of 12 channels on the left and right sides
◆Drive system
BA&MEMS: single-ended drive
Dynamic driver: Balanced drive
Dedicated cable
◆Original 16-wire pure silver cable
◆Exclusively designed Ultimate grade sound quality processing
FUGAKU's greatest feature
It is three hybrid drivers and full analog multi-amplifier system.
The left figure below shows a conventional system and the right is a simplified example of FUGAKU's multi-amplifier system.
The conventional method is amplifier → passive filter → driver, in that order,
FUGAKU's method is active filter → amplifier → driver, in that order.
In conventional systems, there is a passive filter, a circuit for bandwidth division, between the amplifier and the driver, and the amplifier cannot drive the driver directly, resulting in a loss of directness in the sound.
In addition, passive filters must be small to fit into the earphone housing, resulting in a simplified design.
As a result, it becomes difficult to make the frequency response ideal for the designer.
There are several other negative factors in sound quality in exchange for versatility, such as the fact that a single amplifier drives multiple drivers, so the more drivers you add, the lower the impedance, the higher the load on the amplifier, and the more prone to distortion.
To overcome these problems, FUGAKU has adopted a multi-amplifier system.
This is a method that has existed in the speaker world for a long time in a small number of cases.
This is the world's first hybrid-driver earphone and full-analog multi-amplifier configuration, which first divides the bandwidth and then drives each driver with an amplifier prepared for each band.
It is no longer necessary to fit the filter into the earphone housing, and a sophisticated active filter consisting of an OPAMP can be used.
As a result, even higher-order steep filters can be built, and the frequency response that most affects sound quality can be freely designed.
In addition, the ability to use large volumes of high-quality components with large volume, such as film capacitors, makes it possible to achieve high quality on a component-by-component basis.
Not only that, but since the amplifier and driver are directly connected, the driving power is high, enabling unprecedentedly direct sound.
Another advantage is that as the number of drivers increases, so does the number of amplifiers, resulting in a lighter load per amplifier and less distortion.
The supposed disadvantages of this method are the reverse of the advantages of the conventional method.
This method requires a dedicated amplifier and a dedicated multi-pole cable, which reduces versatility and increases cost, but the sound quality benefits greatly outweigh the cost.
While a multi-amp system for speakers requires a separate preamplifier, active filter, and multiple power amplifiers, FUGAKU combines these components in a single housing to provide the ultimate sound on a scale equivalent to a conventional player + portable amplifier combination.
Earphone
◆Drive system
Dedicated cable
Stay updated on Brise Audio at their sponsor profile on Head-Fi.
