Jenz
- Feb 17, 2015
But that must be very new! A few days ago when there was the head sound.de not yet. Thank you for the note!
Man, I've never had such a hard time getting a perfect seal before! Spiral Dots, Symbio, Auvio, Dunu tips all slide right off. Shure, Westone, and narrow SpinFits are too small, can't fit them on. The regular SpinFits and Sony Isolations won't seal. Having gone through my usual suspects, I bought some new tips. RHA dual density, UE white, and KZ Starlines. While the KZ were okay, they didn't seal well enough to preserve the sub-bass. Finally, I tried all my *shudder* generic tips, iBasso, TFZ, NuForce, Trinity, and MEE. Finally, I settled on MEE double flange tips.
Now, the sub-bass hits hard and they sound amazing! They were good before, but that missing piece has finally been added back in. Worth the effort, and I'm glad I didn't settle for the B+ sound with poorly fitting tips.
Agree about the fit of tips being a bit of a pain... FYI, I measured and the nozzles are 4 to 4.5mm with the bump... So ordered some 4mm I.D. tips from AExpress... They seem to fit better. In Comply, that's the T200 series... But like the highs better with silicone tips.
I stopped trying to get the T100's (included with the B400s) because I was needing so much force. - 100% sure that Brainwavz included the wrong size.
I have gotten some large (OD), hybrid Sony copies from China to fit well. They are very stretch so able to fit without too much trouble. But think their smaller bore may be affecting the sound some... The Hybrid Sonys (The cheap ones, Without the foam) have worked well for me with many IEMs)
Note that the Nozzle diameter was said by mfr (in this thread) to have been different on the first production run, so be careful about looking for what "fits" well.... There may be some different nozzle sized B400's.
I have spoken with Brainwavz and they tell me that there are no comply tips for the B400.
Can you put the LINK of the MEE TIPS?
Thanks!
And some Comply type foam tips?
It's possible?
Thanks!
It's possible?
