Brainwavz Audio B400 4-Way Quad Driver 3D Printed IEM
post-13909013
Post #691 of 1,458
I love the preformed wire (fwiw)
post-13909209
Post #692 of 1,458
B9Scrambler
London, Canada
London, Canada
Website
thecontraptionist.blog
I'm right there with you @Brooko.
Forgot to post pics of the revised nozzle on the B400. The revision is a big plus imo because it allows a greater variety of tips to be used and addresses my concerns about potential fragility of the old nozzle design. New one is much beefier. I haven't noticed any affect on sound, then again I haven't a/b'ed the two yet.
Reactions: leobigfield
post-13909259
Post #693 of 1,458
Berakotxa
Does the shure goam tips fit on the new desing?
post-13909289
Post #694 of 1,458
B9Scrambler
London, Canada
London, Canada
Website
post-13910097
Post #695 of 1,458
JetPistol
Germany
Germany
Would you please share the measurements for the reworked nozzle? I've ordered the B400 during the pre-order phase for the next batch so I assume I'll receive that one. I'm intending to use them with Spinfit CP800 and Twinblade - can anyone confirm compatibility with the revised nozzle?
post-13910118
Post #696 of 1,458
B9Scrambler
London, Canada
London, Canada
Website
I'm just using a tape measure so someone else will need to provide more accurate measurements, but it's ~4mm average with that small flare extending out to just below 5mm. Even the stock BW tips are a tight squeeze on the new nozzles.
post-13910856
Post #697 of 1,458
ByDesign
Member of the Trade: Brainwavz
Hello JetPistol,
Here is a drawing of the new B400 nozzle with it’s dimensions. I hope this helps.
post-13911222
Post #698 of 1,458
B9Scrambler
London, Canada
London, Canada
Website
Sweet. My measurements weren't off by much. Not bad for a tape measure, haha.
post-13911226
Post #699 of 1,458
Berakotxa
Hello JetPistol,
Ok, thanks. It doesnt help me. Whats the old size? Thats on milimetres? Are you going to change the provided tips nozzle size?
Reading others answers, im asuming that the shures wont fit on the new desing, so....
post-13911269
Post #700 of 1,458
razzer001
Nothing actually changed to the diameter, there just used to be a indent, which was removed and filled, giving the nozzle a uniform diameter. A ridge was added so that tips wouldn't slip off (this is what the previous indent helped to do).
Nothing was changed to the tips provided and tip compatibility is the same as was with the previous nozzle design.
post-13911376
Post #701 of 1,458
Berakotxa
Ok. Thanks. That help a lot. So now the oudside diameter is the same as the previous one, but the inside diameter is the same than the oudside diameter that gives stronger structural capability to the nozzle.
Im sorry about my bad english skills.
When do you think you can start sending the 3rd lot? Any update?
post-13912418
Post #702 of 1,458
JetPistol
Germany
Germany
Hello JetPistol,Here is a drawing of the new B400 nozzle with it’s dimensions. I hope this helps.
Thank you very much for the quick responses! Are there any recommendations for silicone tips other than the Spinfit CP800? Speaking of foam tips, I already own INAIRS Air 2 which should fit the B400 nozzle.
post-13912545
Post #703 of 1,458
HombreCangrejo
You can try Klipsch Ovals. They are so flexible that even fit in 5mm nozzles, such as Vsonic's VSD3/5, but the intended fit is for narrower diameters.
post-13912676
Post #704 of 1,458
Aevum
My curiousity regarding these would be how do they compare to the RHA T20, The Fiio F9 pro and my current set the Trinity Phantom Master 4.
post-13912749
Post #705 of 1,458
