Ahhhhh! My frosty shipped!!!
Brainwavz Audio B400 4-Way Quad Driver 3D Printed IEM
- Thread starter razzer001
- Jan 30, 2011
Trust me, so do I. Hopefully we can get it there sooner than later.
So we are considering changing the cables that come with the b400.
I would like to know if people would prefer for us to keep the balanced 2.5mm cable or change it for a 3.5mm cable with a 3 button remote and mic? Any feedback would be appreciated.
Hi Razz - thats more a question for your sales department I think. Will most of your sales come from within the audiophile community or outside it? If more are outside it - then it makes sense to supplant the 2.5mm balanced with a good 3.5mm with on-cable controls. If more sales come from the audiophile community, stick with the 2.5mm.
And for those wondering (depending of course on your devices OI) the B400 seems to have a fairly stable impedance curve, and is not affected by small changes in impedance from the source (on frequency anyway). Balanced operation out of the X7ii or X5iii does not measurably change frequency response. Given that other factors like crosstalk, THD etc are beyond the discernible range of us mere humans - then balanced provides no actual benefits for such an easy to drive monitor.
Personally - I'd like to see the on-cable controls. If we had them I'd use them often with my phone. Your next question though would be if/can Brainwavz provide a switchable remote package between Android and iOS - that way including volume controls? FiiO did it for one of theirs. Quite nicely implemented too. That would be an absolute winner.
I belong to the DAP listeners community, but I think that a balanced cable as part of the package is overdone. Being an optional cable seems more sensible to me.
Radec
- Oct 11, 2016
My frosts were delivered 10 minutes after I left for work. Can't wait to get home and get them going. Brainwavz shipped and delivered via FedEx. Package was delivered in around 24 hours from the shipping notification.
littlebuddha
Awesome news - are you in the US? If so where does it ship from? I'm waiting for my black version - kind of wish I had gone with the frosty but hope they get mine shipped soon as well.
shane55
- Apr 5, 2010
I never listen to music on my phone. DAP only while mobile.
One of my DAPs has 2.5 balanced out, and I am looking forward to hearing it... and if I can discern a difference.
So... if as Paul says, there is no discernible difference between the two, then it won't really matter, but buttons and a mic are useless to me, and usually get in my way.
Cheers
Cheers
Radec
- Oct 11, 2016
Yes, I'm in the US. I paid for expedited shipping but didn't expect it to be next day! It shipped from HK.Awesome news - are you in the US? If so where does it ship from? I'm waiting for my black version - kind of wish I had gone with the frosty but hope they get mine shipped soon as well.
- Jan 30, 2011
Cheers
Interested in your impressions my friend. I should add that my tests for discernable difference were performed with the two completely volume matched and having my daughter doing the switching (using a 2.5-3.5mm adaptor) - so single blind. Most SE vs balanced will have definite volume differences, so I'd propose that would be usually the main difference people are actually hearing. YMMV. Mine often appears to be a solitary voice (or at least one of a minority) among a much larger majority of audiophiles who can easily hear the differences
maniac2003
- Jun 20, 2009
Hard to say for me. I like the balanced option but does it really have benefits? I'm not sure if they are audible for me.I would like to know if people would prefer for us to keep the balanced 2.5mm cable or change it for a 3.5mm cable with a 3 button remote and mic? Any feedback would be appreciated.
The instances I use a mic can be counted on one hand but I can imagine it's handy for some.
Overall I would prefer the mic cable as stock with a good balanced cable as a option.
harry501501
3.5mm all the way for me. Although if you use a 2.5 female to 3.5 male adapter would it have any negative effects on sound?
- Jan 30, 2011
None that I have heard - just adds a little bulk.3.5mm all the way for me. Although if you use a 2.5 female to 3.5 male adapter would it have any negative effects on sound?
harry501501
If that is the case, then why not just provide the 2.5 balance with an adapter for 3.5. i wouldn't mind using it. All my sources including daps and amps are all 3.5 and I'd guess it's like that for most casual punters
harry501501
I tell you what, send me a free B400 with the 2.5 balanced cable AND the 3.5 with 3 button mic and I'll get back to you on what's best.
shane55
- Apr 5, 2010
I LIKE the way you think!!
