mbwilson111
- Oct 13, 2016
I don't need a 100 iems like some Headfi members.
Nobody NEEDs 100 IEMS. People who have that many are crazy you know
Or they get them to review and pretend they bought them.Nobody NEEDs 100 IEMS. People who have that many are crazy you know
I thought it would also be my traveling earphones, but their isolation was not sufficient. Maybe the BQEYZ models play so well precisely because they're more sound-permeable.(?)After wasting hundreds of $'s on KZ's I will no longer support the non-smooth metallic sounding brand.
My go-to iem right now is the KB100. What a gem.
That’s a unique thing that BQEYZ does. I’ve never seen it on other BAs.
It acts as a damper, with the intent of it cutting down on any harshness and/or sharp peaks.
I feel it’s one of the primary reasons why most BQEYZ sound as good as they do.
By ‘the sound changed a lot’, can you describe what changed? And was it for the better?
Taking these dampers out was just an experiment, and I had to put them back immediately, the sound changed too much but not better.
So far my tinkering has made the Spring1 get very close in detail to LZ A6 and Audiosense T800, with the warmth that the other two lack.
I am sorry. I apologize. I'm still in the initial embarassment phase.We know, you remind us every 2 days
If my posts ever annoy you, feel free to block me for as long as you need.
How would u rate the Spring 1 in terms of details, soundstage and timbre compared to your other IEMs?
(This is in stock form without mods). TIA!
Timbre is top notch, at least same with blon or better. Soundstage is wide with good depth
Still burning mine since so far the DD is sounded different (better) from that time OOTB.
How is the Spring 1 in details, say compared to your Sony M7? Or maybe even the hybrid/multi BA KZs and CCAs?
As far as I know the measurements of the BQ3 and KB100 are only slightly different? BQ3 has more of everything than KB100. I plan on buying BQ3 soon.I have the KB1 and find its isolation suitable. I would figure the KB100 would be same-ish. Its not? Maybe the boom boom bass of the KB1 helps drown out outside noises?
Im still thinking of picking up a kb100 in hopes it will be the Mother of all Genres IEM. Im just really worried its too laidback. This Kanas I just got is sooooo boring. Very smooth and laidback. Like I am at the back table of a swanky suit and tie Jazz club.
