bedlamite
- Feb 17, 2002
Trying these things out right now. The sound is pretty good, but has anyone noticed the massive noise when connected over 3.5mm? It's especially obvious if you're charging at the same time. Seems like they forgot to shield that part, which is unfortunate since this is the lowest-latecy connection available on the device. Even the direct USB connection has several ms of latency, making it frustrating to use for gaming and musical performance.
If you are getting a hissing\feedback sound when the aux is plugged into your computer, it's probably a grounding issue with your PC and not the fault of the headphones. I get the same thing with these as well as with my HD598s (although not as bad with them). Try driving them from your phone or the like to see if the same sound is there.
Came across this issue last night. Hooked the PX up to my micro iDSD DAC and I was assaulted with background hum and faint static. Changed cables from stock to my spare Sony MDR-1A cable, no luck. I was this close to packing them up to get them exchanged but as a last resort I stuck them into the headphone jack of my Sony phone, then the front headphone jack of my desktop PC. Zero noise in both cases.The hiss is audible even when the aux cable isn't plugged in to anything. Starts as soon as you plug something into the 3.5mm port on the headphones.
tl;dr it's some kinda grounding issue.
