Bottlehead Amplifier Discussion / Comparison Thread: Crack, SEX & Mainline
Mar 25, 2016 at 7:31 PM Post #1,486 of 2,108
I'm considering buying an HD800, and I've heard some back and forth while doing my research about whether the Crack or the 32-ohm S.E.X. is the preferred Bottlehead pairing (aside from the Mainline, of course). I'm sure the issue has been covered a million times, but I can't find that information until the day Head-Fi's search function works better. Any thoughts?
Mar 25, 2016 at 7:50 PM Post #1,487 of 2,108
Doc, is there a way to buy the new shields?
We are only packaging the limited quantity we have with a Mainline order. So I guess the answer is yes, you can buy them from us by buying a Mainline
I imagine they can probably be found on ebay. They haven't been manufactured in many years, but there is probably a supply of used ones around.
Mar 25, 2016 at 7:56 PM Post #1,488 of 2,108
If you are considering S.E.X. I should mention that it is reaching the end of its run, as after more than 20 years of selling the kit we are beginning to experience difficulty in acquiring 6DN7 tubes. I'm sure singles and pairs will continue to be easily found, but our suppliers are not able to come up with the quantities we need for production. I'm guessing we have maybe 5 kits worth of iron left.
Mar 25, 2016 at 8:13 PM Post #1,489 of 2,108
Thanks for the information; I'll keep that in mind. If that's the way I go, I may have to end up on the used market, since I'm still going to be exploring all my options for awhile.
Mar 26, 2016 at 6:39 PM Post #1,490 of 2,108
My SEX 2.1 with output switches is still going strong,  It's an incredible value, being able to drive both speakers and headphones with amazing results.  I enjoy swapping in and out of my system with a Stereomour and my Blumenstein Speakers.  I look forward to leaning about what might replace the SEX if anything can!
Drop Stay updated on Drop at their sponsor profile on Head-Fi.
https://www.facebook.com/drop https://twitter.com/drop https://www.massdrop.com/?clickid=3QR3Ib27lyA-VkBRJwyGuQJeUkhUQvX5r0tLzQ0&utm_term=252901&utm_content=VigLink&utm_medium=affiliate&utm_source=impactradius&irgwc=1
Mar 30, 2016 at 4:18 PM Post #1,491 of 2,108
The Mainline is magic with the Nighthawks... just saying... :wink:
Hey Loquah,
What's been your experience with the Mainline and Nighthawks - specific to output levels/noise -
And, where are the comfortable listening levels for you, etc.
Thanks,
Darren
Apr 2, 2016 at 5:16 PM Post #1,492 of 2,108
I'm running my mainline with hd800's, tweaked with a superdupont resonator and cork mods (google it!) (which replicate the changes in the hd800s, taming of the 6k peak, but have significantly less LF distortion and less of a peak at 15khz, per Innerfidelty). It is headphone audio at its finest to my ears.
Hi Mike, I fitted the French mod earlier today first impression are very good, appreciate the heads up.
Cheers
Jamie
Apr 2, 2016 at 5:47 PM Post #1,493 of 2,108
That would be a real shame as its a great kit. Have you looked into availability of the 6FJ7 tubes as it would only require a socket change for the compactron base.
Apr 3, 2016 at 3:46 PM Post #1,494 of 2,108
Repost from the BHF
So out of curiosity earlier today I removed the 10uf RTI Teflon parafeed capacitors I had been using for nearly 12 months now in my Mainline (the Mainline  ships with a 10uf MKP) and installed the 2.7uf Silver In Oil Mundorf Supreme's that used to be installed in my Sex amp in their place. I was instantly reacquainted with the Mundorfs SIO's distinctive V shape sonic profile and spacious soundstage I remembered from the Sex.
So far I think they sound pretty good with the music I listen to and haven't at this point really perceive any immediate weakness that might be attributed to running a lower UF value.
Going to run them for the week and then swap them out for the 3.3uf Jupiter HT bees wax that are in the Sex at the moment.
Cheers
Jamie
Edit the SIO fit quiet nicely by the way.
Apr 4, 2016 at 12:00 PM Post #1,495 of 2,108
That's encouraging tha 10uF might not be required since the cost gets a bit steep there for the boutique selections. Your testing with the HD800 in the high impedance setting?
Apr 4, 2016 at 1:17 PM Post #1,496 of 2,108
Yes correct hd800 high and in balanced mode.   I picked up a 1 month old Meze 99 classic which arrived at the weekend its Impedance is given as 32 Ohm which I have been running unbalanced in the low setting.  It sound pretty similar on all the amps there are differences but generally the Meze keep the same character. I have tried them so far with Mainline, Sex, and the headphone out on my Leema Acoustics Elements dac. Even direct out of the mobile phone they are quiet engaging but the sonics do take a noticeable hit.
Edit I might add I haven't tried the Mainline and Meze with the 10ufs installed
Apr 4, 2016 at 10:32 PM Post #1,497 of 2,108
Hey Loquah,
Thanks,
Darren
Sorry for the super slow reply, @dmhenley, I've been dealing with some challenging times and not on here as often as usual.
The Nighthawks pair beautifully with the Mainline. There is absolutely zero noise (and I'm very sensitive to / aware of noise) and the sound is magnificent. Given the Mainline's low output impedance mode, you can easily get the sound just right with the Hawks just as you can with the HD800s or other high impedance cans.
I'm yet to try the Hawks running balanced out of the Mainline so I can only assume there is room for slight improvements, but they're so good in single-ended mode that I haven't felt the need to pursue aftermarket cables or modifications to the stock cable.
Apr 5, 2016 at 2:13 PM Post #1,498 of 2,108
No apologies. Hope things get better for you soon.
I appreciate the insight.
I know I will build a Mainline eventually, so it's nice to have feedback on the pairing with the Nighthawks.
Apr 6, 2016 at 6:40 PM Post #1,499 of 2,108
Ok so I need to confess I swapped out the Mundorf SIO, I had listened to them long enough to know their signature in the Mainline is not for me they are super sounding caps and I am sure their signature would appeal to many the 2.7uf worked well enough with the HD800 for me to consider the experiment a worthwhile. But here's the thing after listening to them for a couple of days enough was enough and they just had to come out there was no way I could last a week!
So it was in with the Jupiter 3.3uf HT Bees wax, I left them running for a hour or so and then put the cans on for a listen and just grinned
  there is absolutely no doubt they are just insanely good and in a different league to the Mundorf SIO which just don't sound anywhere near as natural to me. There are differences between the 3.3uf Jupiters and the 10uf Teflons but they are for the most part subtle each has its strong points the Teflon sounding super clean and are incredibly resolving. The Jupiters are more intimate with a softer richer midrange that's just so inviting with the HD800's! Both caps apart from these subtle differences sound quiet similar and both to me are beautifully natural sounding and beguiling in the Mainline. Probably I would stick to the 10uf if running a variety of cans to be on the safe side but if using higher impedance cans like the HD800 or Beyer T1 then running with a lower uf value boutique cap is definitely a option worth considering.
