bikesandguitars
- Jun 28, 2016
I'd also be curious as to how you got your mac to play through AAC as opposed to SBC
I'm running El Capitan at the moment.
Originally Posted by rrocha View Post
You can download the dmg in https://developer.apple.com/download/more/?name=for%20Xcode
It is called Hardware IO Tools for Xcode 7.3 (current version). Mounting that image will reveal BT Explorer. You open the app (which doesn't feature an UI after run)
Then you should go to Tools->Audio Options and see the option to turn the AAC on. (screenshot below in imgur as I'm a noob and not allowed to attach images yet )
http://imgur.com/viyruja
After that, disconnect your headphones and reconnect. AAC should be available from now on. Haven't tried a reboot though, but I'm assuming it's a config that will stay
Bought a pair of these QuietComfort 35. Wow, Bose has really improved from years ago. The Bluetooth range is the best I've ever had on a Bluetooth device. The ability to use the Bose smartphone app to switch between my Android LG G5, my PC's Bluetooth and the Creative BT-W2 USB Transceiver plugged into my PS4 is a godsend. The sound is really good. The comfort is unreal. I'm surprised that a Bose product has Prat and can keep up with a bassline. Highly recommended. It sounds better than Sennheiser Momentum 2.0 to me. It has a nice soundstage. Better than my Oppo PM3 in depth and width. I'm impressed. No more wires to get tangled on in. I'm a wireless believer at this point. I'm surprised by how much I don't miss my PM3. Oh, did I mentioned the noise-canceling is unreal? Now I can listen to my music and movies in peace with no distractions and background noise. My only worry is how long the lithium-ion battery will last. I would have also wanted a USB Type-C connector for charging so I don't put too much pressure the USB connector over time.
I used to own the QC25, but sold them about a year ago as I didn't do much traveling and started using CIEM's instead. However I'm considering buying the QC35 (or 25) again as I've started to travel more and more.
While I loved the noise cancellation on the QC25 I remember that there was a low "buzzing/hiss" made by the noise cancellation circuit when it was on. How is this in the QC35? Is there just no "noise" added when they are on? ie. if you are in a already completely silent room - then turning them on shouldn't add more noise - they should just "be quiet".
From my brief demo they felt a lot better in that regard. The old ones used to have sort of a tension to them, if I can put it that way. I was shocked at how well they perfectly quieted a noisy store. I'd never considered getting some of these but both SQ and noise-canceling have improved to the point where I'm intrigued. Jeff
I decided to buy the QC25 again after comparing them with the 35. There was very little difference in sound "quality" (not better/worse, almost sure it's the same) and the ANR was exactly the same. The only difference seems to be the bluetooth connectivity that almost everyone has issues with.
So since sound and noise reduction is the same - I decided on the QC25 again. The cable always works, and when travelling (primary purpose for these) it makes so much more sense with easy replaceable AAA-batteries.
http://www.innerfidelity.com/content/outstanding-bose-quiet-comfort-35-wireless-noise-canceling-headphone-page-2#4IyhhZjabKA5raXH.97
My question to anyone that owns these... have you tried using the mic+sound on a Mac? Did I just get a bad one? I already returned them but would be willing to give them one more shot if this isn't normal as they felt so good on my head.
any update? curious where you ended up
I've used mine with facetime and skype on a MBPR and iphone with no problems. Would give it another shot if I were you
